my 318is
punk_sy
Post Sat May 31, 2008 2:00 pm
hi bin here a bit just got round to posting these and some new springs and shocks!
there (crap) pics of the day i got the car !!
these are from last night fitting the bilstein and eibach springs 8)
hammoj28
Post Sat May 31, 2008 2:37 pm
Looks nice, any piccies of the springs in? Prob ain't settled yet tho.lol
24v tech2
motorsport325i
Post Sat May 31, 2008 2:44 pm
looks nice mate :cool:
punk_sy
Post Sat May 31, 2008 4:00 pm
yea just took some for you. i think the the backs not much lower but the front deffo is. will it get any lower ? i thought it would be!
still need to fit some doors but i think ill get a e36 rack next because the steerings wank!
hammoj28
Post Sat May 31, 2008 4:16 pm
Looks good. bet it handles great!! Im sure it will settle a fair bit, depends how many miles you have done.
24v tech2
appletree
Post Sat May 31, 2008 4:23 pm
Ive got the same kit as you and thats just how mine looked and after 350+miles it realy started to settle down. :D
punk_sy
Post Mon Jun 02, 2008 10:28 pm
hammoj28= yes the handling is so much better well i havnt totally canned it yet because of the bearing but i like it :cool:
ive also come across the reason of it not handling well before......the n/s shock was fudged (i mean no oil left in 8O ) also the n/s wheal bearing needs changing . both i knew about but wot i didnt no was this;
the springs were different sizes which must mean some numpty has fitted a whole new strut to the car at some point!!!!! but the wrong one.
thanx for all the comments lads :)
josh-hocking
Teenager with Taste !
Post Tue Jun 03, 2008 5:42 pm
:eek:
punk_sy
Post Fri Sep 05, 2008 12:47 pm
Im not 100% pleased as i shud of laquered the black bits in the headlights and you can see the glue in the beams but looks better than before..
ive also painted the grills and still need to put the eyebrows back on but not sure!
also leaving the n/s beam out to fit a induction cone
aj_mckay
Post Sat Sep 06, 2008 8:05 am
Which Bilstein dampers did you go for? I think I'm gonna do the same with my iS but not sure which dampers to go for - there are B4, B6, B8 etc. available I believe...
Yours looks really nice how it's sat - nice and level, not lower at the front. That's what I'm after and I bet it handles sooo much nicer!
punk_sy
Post Sat Sep 06, 2008 3:28 pm
their b8 dampers ill get a pic of what it looks like now when it stops raining :o the front does seem to sit lower but it doesnt rub or ground out on speed humps only with 4 people in it scrapes a bit sometimes..
and yes it handles great might put some better anti roll bars on it tho
aj_mckay
Post Sun Sep 07, 2008 10:44 am
Did you change any bushes when you did the swap or were they OK? might want to try that before changing the ARBs as they're pretty good on the iS as standard anyway!
Baz666
Post Sun Sep 07, 2008 4:22 pm
punk_sy
Post Tue Sep 09, 2008 6:39 pm
This is what its settled to now but at the moment i am running different size tyres (cheap ones for drifting) on the front ive got 205/50 and the rears are 205/60 . i only changed the rear top mounts when i did the suspention. but before the arbs im polybushing most and m3 wishbone bushes. but it feels like it rolls to much to me :mad:
The car is dirty and dont look to much at the paint :(
punk_sy
Post Sun Feb 15, 2009 7:52 pm
well ive got my arse into gear and bought a runabout to carry out my m50 convertion to my IS. This is what ive bout its a 520i se not bad really just like driving a floaty bus :mad:
well as the fudging e34 wouldnt start or run proply today to get some bits for it i started stripping the E30.
not much rot there :) check my pink speakers lol :o
still the sound dedning to come out!
took the servo out!
This is where i got just got to disconect the prop, gearbox mount,exhaurst and a couple of little bits then the engines out. NOT to bad for 3 hours work. :?
Gonna take the other wing off and trailer it to work to steam it all of then paint the inner arches and seam weld some of the struts etc.
Post Sun Feb 15, 2009 9:45 pm
no going back now m8 should be a fun project :wink: will try get the EWS sent of this week I forgot about it :o:
