9's on the back of a e30?
jph78
Post Mon Jan 24, 2005 10:24 pm
I'm gonna put some 9 inch wide rims on the back of the touring (following some extensive arch work) and am trying to decide what size tires to use?
I'll be running 205/40/17's on the front and 235/35/17's on the rear would be a good match for the rolling radius.
Anyone got any suggestions? Ive seen a couple of people are using 225's, but not 235's.
Cheers, Jon
Davenotouring
Post Tue Jan 25, 2005 12:23 am
On the back mate,
If you run 205/50/15's on the BBS's then the rolling circumference is 1841mm.
If you use 235/35/17's on the back of the new tyres it will be 1874mm, quite a good match! Less than 2% out.
205/40/17's are 1872mm. This is what I run on mine.
Look at this site.
http://www.bolide.co.uk/actions/info.ta ... calculator
BMW 328i Cab - Daily Slag
jph78
Post Tue Jan 25, 2005 12:35 pm
Cheers Dave, but if you re-read my post you'll see i already calculated this was the best match for the circumference! Thanks for the link anyway dude.
I was just interested if anyone was running 235 wide tires on the back, and what clearance probs they had?
Davenotouring
Post Tue Jan 25, 2005 1:52 pm
Oh sorry mate!
That link is useful!
Anyway....hopefully someone will see this!
BTTT
