As you can see the rear is lower then the front (40 mm all round) however if I jack one side up and rotate the spring then lower again I find the ride height is higher, I then do the same to the other side but then the opposite side I just jacked up lowers itself again!
Long story short I got someone to hold one spring steady while I jacked up and rotated the spring on the opposite side of the car, lowered the car and hey presto both sides were the same height (didn't last long) drove to work and what do you know one side is higher then the other.
Which leads me to believe the springs move slightly when in operation, they are Jamex 40mm springs does anyone have any ideas. Would putting standards in the rear make the height much higher?
Im going round in circles with this one
