Door Locks...
Guest
Sometimes my passenger door locks by using my key in the drivers side door lock and other itmes it doesn't... Any ideas what's going on?
elliot
open the drivers door, pull off the rubber shroud, get a small terminal screwdriver and push each one of the terminals in carefully.
try this first and report back soldier
elliot
elliot
elliot
there should be a rubber cover type thing in the piller between the hinges on your door, pull it off and you will be met with a multi connector.
elliot
elliot
