Door Chime?????
everhard
Thu May 22, 2008 5:36 pm
Hi guys Ive got a 325i se late 91
Should i have a buzzer to let me know ive left
my lights on??? It chimes if the temperature drops below 6 !!!!!!!
If i have where would it be??
Cheers....
Don't mind two much!!
But three much is two much!!!!
Thu May 22, 2008 5:37 pm
They weren't fitted as standard, but are quite simple to retrofit. See these threads
http://www.e30zone.net/modules.php?name ... ing+buzzer
http://www.e30zone.net/modules.php?name ... 30&start=0
everhard
Thu May 22, 2008 5:44 pm
Cheers speedtouch :D
FlappySocks
Thu May 22, 2008 5:48 pm
I have been thinking about making some up, which will also have an interior light delay, and a moisture sensor. The moisture sensor tells you when you have water under your carpets, which seem to be a big problem amongst zoners recently :roll:
