300mm.de does engine mounts for E30 M60/62 !
Andy335Touring
Post Mon May 12, 2008 11:32 pm
I'd not noticed this before so i assume they are fairly new, heads up potential V8 swappers ! :cool:
http://www.300mm.de/typ5/typ5.html
FormerMember
Post Tue May 13, 2008 4:15 pm
They've been there for months ;)
Anyways, it's good that there're V8 mounts available, makes things a lot easier.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Andy335Touring
Post Tue May 13, 2008 11:18 pm
my bad, first time i'd noticed them
GrindCulture
Post Fri May 16, 2008 6:16 pm
┚¬199 for a full set? My German isn't all that good...
Not in E30s any more :(
bigdek
Post Fri May 16, 2008 6:42 pm
Jonsku wrote:They've been there for months ;)
not really . the mounts are east to make . if someone was to sell exhaust manifolds then it would be an easier swap as thats the biggest pain in the ass
glenn
Engine Transplant Services
Post Fri May 16, 2008 8:30 pm
Andy335Touring wrote:I'd not noticed this before , heads up potential V8 swappers
andy, what were you doing looking at v8 engine mounts for ? :D
Andy335Touring
Post Fri May 16, 2008 11:05 pm
I wish ! :)
No, i was looking at the brakes.
oze30
Post Sun May 18, 2008 6:33 pm
Manifolds for me!!! :(
suzie650
Post Sun May 18, 2008 6:58 pm
There is a solution for the manifolds. Still needs a bit of tinkering on the downpipe bit, but the manifold part itself fits straight on...
E39 ones! (Before anybody asks, the e39 m5 have the same shape as the e34 ones but a different bore)
And I'm kicking myself, because I bought the only set I could find in England from FAB just to realised when I got them that I once again forgot that my car was lhd... And obviously the starter/steering problem is reversed. As if relocating the starter motor hadn't been enough of a lesson... Why can't you sit on the correct side of your flippin' cars???
And FAB charge you 25% if you return them their stuff :cry: :cry: :cry:
I'll have to find a minute to stick them on ebay
Concerning the 300mm.de, I don't like them that much. It's possible to fit the engine as close to the subframe and as far back as it goes (starter and heater hoses to bulkhead clearance) without spacing the subframe, even with a 6 speed 'box, but not with that design.
Karan
Post Mon May 19, 2008 6:24 pm
having spaced my subrame i think people get too caught up on it
suzie650
Post Mon May 19, 2008 11:20 pm
What the guys in germany say about it, is that as long as you stick with an e30 suspension setup, it's fine. (no e36 m3 to get 5x120 on the front, or you get a horribly light steering)
My problem with it was more that I am hoping to get the car road legal in a country where wheels or exhausts can be a problem on their own. Let alone an engine swap. And a spaced subframe would be a no-no straight away. Mind, the subframe has been "customised" a fair bit...
jaistanley
Post Mon May 19, 2008 11:55 pm
If you have E30M3 front suspension you can get roll centre compensators to fix it (spacers that go at the bottom of the struts to lower the ball joints)...
As for using the E36 M3 stuff, if you choose the right parts you get the same geometry as the E30M3 stuff (but obviously can't add the roll centre spacers). That is: Evo hubs, TCA's, Eccentric bushes and adjustable topmounts if you want to be fancy. The light steering comes from close to 0 camber and around 7 degrees of castor when using the 3.0 litre M3 stuff and non evo TCA's.
I looked into it... lol
oze30
Post Tue May 20, 2008 10:31 am
Jai,
Do you have a link to these roll spacers??
Karan
Post Tue May 20, 2008 1:56 pm
muzzi motorsport do them, or measure up and get some machined ureself
Post Tue May 20, 2008 2:09 pm
what do these spacers look like? without thinking about it too much, i cant picture how it would work on an e30..
Andy335Touring
Post Tue May 20, 2008 4:29 pm
Jhonno wrote:what do these spacers look like? without thinking about it too much, i cant picture how it would work on an e30..
http://gsperformance.com/products/rc-spacer/spacer.htm
Post Tue May 20, 2008 5:11 pm
Ah legend!! makes sense now.. Didnt realise they came apart like that!! :cool:
Karan
Post Tue May 20, 2008 5:16 pm
my steering is very light actually, even with the e36 rack. My camber is almost 0 too lol
havent really been ragging it round croners as i only really use it on the mway but i do need t sort this to improve the handling as its properly boat like at the moment!
Post Tue May 20, 2008 5:24 pm
I have no idea what mine is like.. Hopefully will soon tho :D
This will be one of my areas of spendage however :cool:
