refurbing Borbet A's
pauldeacs
Post Mon Apr 21, 2008 7:45 pm
Recently picked up some 16x9 borbet A's that had seen better days and have started to refurb them as you can see from the pics below. the dish will eventually be mirror polished when i get round to buying some good metal polish.
i initially used paint stripper to get rid of the scabby paint and clear coat and then hand sanded/polished the dish using progressivly finer grades of wet and dry.
wheel centres were primered, painted and laquered.
gadjit
Boost Junkie
Post Tue Apr 22, 2008 1:39 am
Hey Dude
They look awesome,,,, ( Now )
How much did you pick them up for ?
You have certainly put a lot of work into making them look fantastic,,
Love the coloured centres too, did you paint them yourself ?
Well done Dude,, post a pic of your 30 when they are done and on.
Regards
Gary
Rallyprep_UK
formerly Driftnething
Post Fri May 09, 2008 11:03 pm
i wanna c em on yer car mon ;)
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri May 09, 2008 11:44 pm
Scruffymurphy
Post Sun May 11, 2008 3:11 am
They looked really ruff before, fair play to you, they look very goo now.
aceraf
Post Sun May 11, 2008 9:52 am
Should've polished the dish whilst you were at it, easier to do it all at once while they're clean.
Centre's look good.
Breaking 325i Touring
pauldeacs
Post Sun May 11, 2008 10:25 am
aceraf what technique did you use to get the real mirror like shine on the rims? i want to get mine like that.
aceraf
Post Sun May 11, 2008 10:50 am
At the time i just used finer and finer grades of wet + dry.
I have since used 00 grade wire wool on them, and that seems to remove any harsh scratches (that won't polish out) and replace them with very fine scratches (which will polish out).
I spent alot of time trialling different polish's aswell to see what gives the best finish, and the one I recommend is Meguiars NXT Metal Polish. It cleans any imperfections out very well, and also gives a superb finish, whilst repelling water aswell (and thus helps when it comes round to cleaning them). There are better products out there, but i use that whenever i clean the wheels (every 2-3 days) as it's easy to use. I apply 2 coats of it, and it keeps the wheel well protected.
I flatted mine down using a sander and P240 and then gradually worked upto P2000. You could try using the wire wool after the P240 to try and remove the harsh scratches and it should make life a little easier.
They should look good on your car with the polished dish.
