What other wheels fit e30 4 stud ie Renault, Honda???? etc
rwdonly
Thu May 08, 2008 1:02 pm
Im just wondering what other manufacturers wheels fit on the E30 4 studs?
Can i put a set of aftermarket Renault alloys on my touring? You get the idea.....
Thanks :D
tailoutcharlie
Thu May 08, 2008 6:54 pm
According to good old Practical performance car mag...
e30= 4x100, 57mm center bore, 18-25 offset.
Renault 19/21/laguna/espace/clio = 4x100, 60mm center bore, 35-38mm offset.
so the wheels will go on but will not sit right in the arches either requiring spacers or sticking out too far, i think (can never remember which way offset works).
Chris
gareth
Thu May 08, 2008 7:01 pm
in that case, spacers will be needed. also, the wheels won't centre without sourcing correct spigot rings (easy enough on aftermarket wheels)
that said, you should use hubcentric spacers otherwise the centres won't locate anyway and you'll get horrible wheel wobble.
riklusby
Sat May 10, 2008 7:54 pm
If my memory serves me right, some vw wheels will fit but have wrong offset and center bore
gareth
Sat May 10, 2008 8:05 pm
vw 4 stud is the correct pcd (4x100) and centrebore (57.1) but is usually the wrong offset, needing spacers
rwdonly
Sat May 10, 2008 9:18 pm
Cheers guys its interesting, as soon as you say "Bmw" people just seem to think £Â£Ã‚£ kerching!! :x
I thought it might be an easier way of getting some decent wheels instead of my 14" " Bottletops ".
tailoutcharlie
Sun May 11, 2008 10:56 am
unfortunatley rwdonly, bmw decided to use a pretty unique offset for the e30 meaning nearly all other wheels will need specers. you'll need to budget a fair bit o cash for decent hubcentric spacers like H and R etc cos like gareth sais cheap ones will lead to wobbling at best and a wheel comin off at worse...
Chris
riklusby
Mon May 12, 2008 7:50 pm
I had 20mm spacers on the rear of my car before i started the kit and even driving carefully i found myself wobbling about on sainsburys car park, on careful inspection i found only 1 badly bent wheel nut still holding my 9x16 on the back the rest had sheared and were rattling about behind the center cap, i will NEVER use anything other than hubcentric spacers again and strongly advise anyone not to do so 8O 8O 8O 8O
BB-BMW-325i
Mon May 12, 2008 8:04 pm
Toyota MR2 MK1 & MK3 wheel will fit but you will need spigot rings and possibly spacers.
http://www.e30zone.net/modules.php?name ... c&start=75
Here is a photo at the Brum meet with my 16" Fox raceing 5 on From my MR2.
Youtube Google ebay sony wii: Increase Your trafic here.
Alburglar
Thu May 15, 2008 1:12 am
mark 3 golf
M42 - rightness! with proper 4.27 LSD
rwdonly
Thu May 15, 2008 9:24 pm
MMM i think this is coming through loud and clear!
There doesnt seem to be an easy way of getting around it, i did speak to someone else about swapping parts over to change the bolt pattern to a more friendly BMW 5 stud, this may be the way for me.
I really appreciate the time you guys have taken to answer, thankyou, the more i work on my car, the more i appreciate it.
:wink: :wink: :wink: :wink:
Thu May 15, 2008 9:33 pm
the only way to go 5 stud properly is to source M3 stuff, not cheap and you'll probably be a grand out of pocket before you get round to even looking at some wheels
I quite like the idea of the Mk1 clio 16v turbine alloys on an E30
rwdonly
Thu May 15, 2008 9:38 pm
Whipsey was the one that advised me about converting to 5 stud, he did list the parts but ill be honest i had my head stuck into a V8 at the time and didnt really pay too much attention.............
not a bad place to be :cool:
rwdonly
Thu May 15, 2008 9:46 pm
LOL better than listening to Whipsey prattle on about " Rollocks!!" 8O
hongkongfuey
Mad-tango-geezer
Thu May 15, 2008 9:51 pm
with cars like mine,
rwdonly
Thu May 15, 2008 9:54 pm
Excellent!! thankyou my mild mannered janitor friend....... no thanks! :wink:
rwdonly
Thu May 15, 2008 9:57 pm
A quick flick through and it looks like im in trouble ( the bore size is pretty unique )...... :x
gareth
Thu May 15, 2008 11:53 pm
the bore size on almost all wheel fitment guides is wrong in the case of the 4 stud E30. it's 57.1mm, the same as VW.
whipsey
Fri May 16, 2008 3:35 pm
rwdonly wrote:LOL better than listening to Whipsey prattle on about " Rollocks!!" 8O
you love it you slaaaaggg
whipsey
E30BeemerLad wrote:the only way to go 5 stud properly is to source M3 stuff, not cheap and you'll probably be a grand out of pocket before you get round to even looking at some wheels
you can use some e36 components a grands just silly
whipsey
Fri May 16, 2008 3:42 pm
http://www.ubersaloons.co.nz/uber3/5lug.htm
thought i better post this link again for the people who don't know of the other non m3 route winkeye
rwdonly
Fri May 16, 2008 6:22 pm
gareth wrote:the bore size on almost all wheel fitment guides is wrong in the case of the 4 stud E30. it's 57.1mm, the same as VW.
The same as VW? What do you reckon to that Whipsey?
Cheers for chiming in mate!! :cool:
whipsey
Fri May 16, 2008 6:23 pm
my old alloys from my black e30 went on a mk2 golf
rwdonly
Fri May 16, 2008 6:34 pm
NOOOOO U FOOL where do we go to every bloody day? And no dont shout it out, but what are we surrounded by??? mmmmmm gti? winkeye winkeye winkeye winkeye
whipsey
Fri May 16, 2008 6:42 pm
five stud you pillock
rwdonly
Sat May 17, 2008 10:22 am
Yes exactly hence the , oh yeah theyre all new arent they and theyre all bloody 5 stud even the polos!
Dammm you VW :x
