E36 ignition barrel ? Urgent help please.
beefy
Post Fri May 09, 2008 8:09 pm
Hi got in car today turned the key and it just kept happily turning round in the barrell without engaging anything. After some fidling with the key it engaged and started. Got home tuned key and nothing and the engine kept running. I also took the key out of the ignition with the engine running. Killed engine by removing fuel pump fuse and have disconected the battery as the ignition was still on.
Do i need to fit a new barrell or is there some other way to fix this?
Any ideas how much one would be?
Oh yeah its p reg 328i sport. Cant use car so i need to sort it soon as.
E30 M30 Mounts £100 pm me for info.
beefy
Post Sat May 10, 2008 2:35 pm
Have tried to i it out with 1mm pin but cos it so far gone it wont come out,
How do i remove the barrel and cause minimum damage.
Help please before i start smashing at it with a chisel-
siddiqi1
BFG Zone Contributor
Post Sat May 10, 2008 3:33 pm
i spoke to someone who was in ECP buying a igniton barrel for an E36; he said it was quite common; but unfortunately did say he had to damage the cowling around the steering wheel and break it out!
but im no expert of E36s; but that was he said!
Post Sat May 10, 2008 7:28 pm
If you can disengage the steering lock there is no need to damage anything, before trying to remove the barrel I would take the switch of the back and check it out first
Post Sat May 10, 2008 7:29 pm
Also as your car will have EWS you need to keep the key chip
beefy
Post Sat May 10, 2008 7:55 pm
I got it nearly all out today just a little bit at the bottom left in which should just pull out but id had enough of it.
Didnt cause much damage had to chisel the shear bolts out.
Apparently it is a common fault the new barrel coded to the present key is about 50 quid from the dealer.
There supposed to come out the same as e30 ones with a pin. But this didnt work as the hole thing was just spining.
Brocky325
Post Sun May 11, 2008 6:48 am
Shame i did'nt see this thread before , might have been of us to you http://www.bmwland.co.uk/talker/viewtopic.php?t=42050
