Goodridge Braided Brake Lines
toby
Post Thu May 08, 2008 9:19 am
Many thanks to Ant at A-Tech for fitting some new brake lines on my touring.
I found this a real confidence inspiring upgrade in as much as the brakes respond more quickly and bite harder now. It is noticeably easier to shave off a little speed just when I need to. There's just a little more 'feel' through the pedal now too.
I started with this. I got the fluid from Euro Car Parts for £10 and the brake lines from ebay for about £65.
First Ant sprayed the old connections with penetrating oil.
This one was a sod and it had to have a flame on it before it would undo.
These flexible pipes that go over the rear beam were so tight we didn't want to risk rounding anything off so I will leave these until I have to replace the whole brake line back there or have to take the petrol tank out for some reason.
Must fix that leaky diff :roll:
New lines installed
The new fluid was fed in and I went out for a thrashing. I only got to the end of the road before I had to do an emergency stop to avoid some scatty fool and immediately the improved response was appreciated.
I left the existing pads and discs as they were in ok condition. I now also have the benefit of seeing what this upgrade does on its own. The brakes are quite noticeably sharper and stopping distance is slightly reduced. The pedal is a touch firmer too. Considering there probably isn't much between the cost of these lines and BMW rubber lines I'd say that this is a great upgrade for the money.
I've got much more confidence when I squeeze my brake pedal now. The old fluid was in the car for ages and none of the old pipes were leaking but even so I'd say the brakes are much improved.
I'm going to try the ATE power discs and Mintex C-Tech pads from ECP next so I can see if they have a different effect compared to stock parts on my car. I love how you can upgrade these cars at little extra cost compared to simply replacing with stock parts if you wish to.
Toby
AlpineAde
Post Thu May 08, 2008 1:08 pm
Very nice.
I wish the Goodridge stuff was ADR compliant, but it ain't so we can't use 'em here in Australia. Bah! I say!
It's a real pity because I've only ever heard good things about their product.
toby
Post Thu May 08, 2008 1:28 pm
What's ADR? Australian Design Rule? It sounds stupid. I feel a 'Clarkson-inspired-hatred-of-overprotective-rules-moment' coming on and it's not even UK Health and Safety Legislation this time.
The hoses should last a long time although are still prone to wear in some way.
AlpineAde
Post Thu May 08, 2008 1:32 pm
Yeah...it's our own particular compliance thing. It's a right bugger as I know how good those braided lines are.
It sort of opens up a can of worms, too, in terms of ~ heaven forbid ~ an insurance claim. A really keen assessor could void your claim if non-ADR components are found on your vehicle. You'd have to be unlucky but it could happen.....
siddiqi1
BFG Zone Contributor
Post Sat May 10, 2008 12:46 pm
Ive got these fitted on my car; have had them for some time! i found thewy made my pedal firmer aswell; but do you belive somewhat that is phychological; is it the feeling that you want an improvement and almost make yourself belive it???
Ive got crappy Greenstuff on mine at the mo; and its appauling braking; but it was improved over the standard line i felt; why did you move to a different brake fluid?
toby
Post Mon May 12, 2008 9:44 am
I believe that any claim for an improvement above 'slight' for this upgrade is a fanciful one.
Brake fluid has been recommended on the forum. It was cheap and easy to get, it has a higher temperature operating range, reducing the possibility of brake fade plus I think it is less hygroscopic than standard fluid (it attracts water less) and therefore retains a greater efficiency.
siddiqi1
Post Mon May 12, 2008 10:06 am
ah ok; I shall go and buy a bottle of this stuff to then; would you use for clutch fluid tooo?
toby
Post Mon May 12, 2008 10:09 am
Yes. I was going to do that too but I forgot my new clutch pipe :mad: I will replace clutch slave cylinder, pipework and fluid at some stage.
siddiqi1
Post Mon May 12, 2008 11:49 am
oh nooooooo; could have got it all out the way in one go! Nevermind! Do you mean the metal copper pipework, or just the rubber hose from the tank down? If i recall; i think goodridge do a S/S clutch line toooo!
toby
Post Mon May 12, 2008 12:20 pm
I will get it all done in one go next time. My slave cylinder is still ok so I will wait til that is a bit older and do the whole lot. I've already got the rubber pipe from BMW. The fluid comes in 1 litre bottles and although I've probably got 1/4 bottle left I'd like to get a bit more fluid just to make life easy and to be sure I have enough as sometimes the clutch needs to be bled several times.
There are reinforced clutch lines available for E30s.
http://www.dedericmotorsports.com/catal ... ucts_id=40
A brief look didn't reveal any UK suppliers but there probably are some.
siddiqi1
Post Mon May 12, 2008 12:53 pm
im sure ive seen the goodridge clutch line on ebay! have a look there!
my clutch took forever to blleed; the mech was swearing and the lot!
where can you get the AE blue racing fluid from then!
e30325itourer
Post Tue May 13, 2008 12:33 am
toby wrote: I got the fluid from Euro Car Parts for £10 and the brake lines from ebay for about £65.
:D :D :cool: :D :D
THE ULTIMATE DRIVING MACHINE
siddiqi1
Post Tue May 13, 2008 9:35 am
thanks! :)
