what has everyone done with there harness mounting points? im using a 6 point harness and at curent only have enough points to mount the shoulder straps. and one lap strap so will need to get some welded in. has anybody got pics of what they have done? would make it alot easier to explain to my welder what i want done if i have a pic.
cheers
mike.
harness mounting points.
Trise30rally
Drill a hole in the transmission tunnel and bolt an FIA approved eye bolt in with the backing plate, you do not have to weld anything just bolt it in and off you go!
If you insist on using 6 points you will have to do the same with the other 2 points where you see fit!
mikekean
ahright i thought they had to be welded, i thought i may aswell fit a 6 point if i was going to need one welded in anyyway. might just go for a 4 point now.
Brian28
The extra 2 points are just a couple of holes through the floor under the seat, so may as well stick with a 6 point.
For sale - E30 320i racer project - sold.
agent006
Mine are mounted through the floor with spreader plates welded underneath.
mikekean
isnt the floor double skinned in that area though?
Brian28
Single skin, just drill through and bolt the eyes into a spreader plate underneath.
mikekean
cheers for the advice guys. nice to see its going to be alot easier than i thought.
