It needs a passenger wing, big patch on passenger 'jacking point', drivers door, sill and lower rear quarter (have the panels but a pig of a job), paint on bonnet and drivers wing, backbox repair/replace (small hole).
It currently has:
A very good M20B25 that comes from a 64,000 mile Auto. Pulls like a train. I just adjusted tappets, fitted new plugs, rotor arm, oil, filter and a very swish painted rocker cover
Full E30 M3 running gear with: rebuilt and painted front calipers, new (ish) disks, 1/2 worn pads, Goodridge braided brake hoses, Bilstein B8 dampers (2 years old and front only - I need to keep rears), H&R iS springs, poly TCA and rear beam bushes, poly front arb bushes, newish M3 droplinks.
15" M3 BBS wheels in quite nice condition. Front tyres have loads of tread left, rears are almost worn out (though very even wear which tells you suspension is all straight). All 4 tyres are Khumo Ecsta Sport KU31's.
Quite nice iS lighter grey interior with only the vinyll on the passenger seat peeling back a bit to let it down.
Black headlining.
Slightly worn Mtech1 steering wheel.
4.1 Medium case LSD with ZM bush. Came from a low mileage American M3. I changed the oil but that was probably 20-30k miles ago.
So is it worth me fragging the car? It's not worth that much as a complete car as it's dog ugly and like food, the first bite is with the eye.
I'm considerng buying myself a runarround.. 306 Turbo diseasle or a micra 1.3 till I finish my other E30.
The above morsels are all worth quite a bit aren't they? Some (like the dif and the running gear) are quite highly sought after so I could probably have the money pretty quick.
Any opinions or suggestions gratefully recieved. Is it worth killing the poor old girl? I shan't be leaving the E30 flock. I would probably have a bit of cash over after getting a runarround to buy some bits to get the S50 powered 325i I have on the road
