what gearbox
whipsey
Post Tue Apr 29, 2008 7:34 pm
what gearbox will i need for a 2.5 m50 swap? do i need the original m50 gearbox or will an m20 one fit?
12345kevin
Post Tue Apr 29, 2008 7:47 pm
You can use the M20 Box, which also means you can use the flywheel, clutch, prop and diff :D The gearbox will turn about 10 degrees I believe, which means a bit of work on the linkage and the gearbox mount is needed.
Ant did this with my car and it all works well.
whipsey
Post Tue Apr 29, 2008 7:48 pm
any idea what he did? more importantly do you have any pics? winkeye
ed325i
Post Tue Apr 29, 2008 9:21 pm
Read this >> http://www.e30zone.net/modules.php?name ... highlight=
I have a m50 gearbox and flywheel here if you need one.
