Dash Lights
AndyMack
Post Thu Jun 16, 2005 5:48 pm
Ok i think some of my lights dont work. Are these going to be bulbs that dont work anymore? Or maybe a fuse? Or someone said a battery that powers the service lights?
Any advice?
orkboss
Post Thu Jun 16, 2005 5:54 pm
looks alright to me. Same as my ignition on I think.
e30nerd
Post Thu Jun 16, 2005 5:57 pm
yep all ok. do the serivce indicators light up on ign. stage II
Also I assume you have not got your fogs on? The brake warning light (next to the hand brake) will only light when the wire in the pads goes open circuit
AndyMack
Post Thu Jun 16, 2005 6:02 pm
e30nerd wrote:yep all ok. do the serivce indicators light up on ign. stage II
That is stage 2. The service indicators never light up.
The owners book said the brake warning light should come on with the rest of them. no?
Martinaston
Post Thu Jun 16, 2005 6:07 pm
the one thats not on is the brake fluid level.
The service lights could be the internal batteries
AndyMack
Post Thu Jun 16, 2005 6:09 pm
Martinaston wrote:the one thats not on is the brake fluid level.
So should it come on or not?
How easy are the internal batteries to change?
Martinaston
Post Thu Jun 16, 2005 6:10 pm
Ive got the brake lights the wrong way round
but it should still light up for the lamp test.
As for the service indicator
the batteries in the instrument cluster have possibly died and will need changing or the circuit board could be loose either way you have to strip the unit to find out
Martinaston
Post Thu Jun 16, 2005 6:16 pm
to change them you have to solder in new ones but be careful not to heat them up with the iron or you ruin them
m1key
looks like you need some fuel !
AndyMack
Post Thu Jun 16, 2005 6:21 pm
Martinaston wrote:to change them you have to solder in new ones but be careful not to heat them up with the iron or you ruin them
Hmmm sounds like more hassle than its worth. :(
Yeah i do need fuel.
gazza
Post Thu Jun 16, 2005 6:41 pm
it really s not difficult just make sure you get the correct batteries first....some are nicad rechargeable and some are lithium and are not rechargable
Image design cab and now 325 touring
AndyMack
Post Thu Jun 16, 2005 7:06 pm
gazza wrote:it really s not difficult just make sure you get the correct batteries first....some are nicad rechargeable and some are lithium and are not rechargable
so how do i get to them? take it i cant just take off the bottom part of the dash and get to them?
can i change them to rechargable ones so i dont need to do it ever again?
