loom swap
jaffro
Post Sun Apr 20, 2008 4:33 pm
ive just bought a pre'face325 and want to drop it in my cab till winter when ill be doing a m50 swap. is it worth me updating the management system on the 325 to the later style loom a sensors. also to add the cab its going in was running the later system on the 2.0 that was in it before. so what would i need to change on the 325 engine to make it run in the cab :o:
jaffro
Post Tue Apr 22, 2008 4:38 pm
also to add the older system is also motronic but with the sensors on the gearbox??
ed325i
Post Tue Apr 22, 2008 5:20 pm
Swap the sensors / engine loom etc from the 2.0 engine over to the 2.5 put the 2.5 (late) chip in the 2.0 ECU.
jaffro
Post Tue Apr 22, 2008 5:35 pm
cheers ed. do i also need to put the toothed pully off the 2.0 onto the 325 lump :o:
ed325i
Post Tue Apr 22, 2008 9:34 pm
Yes you do as it will have the bit on it for the front crank sensor to read.
andyr
Post Tue Apr 22, 2008 11:13 pm
I know where you goin ta get this little lot from..... :wink: :wink: :wink:
ric325i
Post Wed Apr 23, 2008 9:04 am
andyr wrote:I know where you goin ta get this little lot from..... :wink: :wink: :wink:
he has robbed most of it from me :D
ahh but carl needs the loom :)
jaffro
Post Wed Apr 23, 2008 4:11 pm
andy you have a tx lol. :cool:
