speedo print board replaysment
dn808e2
Thu Apr 17, 2008 9:33 am
hi, e30 m3 printboard on the back of the speedo is burned out a little bit,
can it be replaced by 325 LHD car speedo, or can i just replace the small print board at the back or burned resistor?
abelai
Thu Apr 17, 2008 9:42 am
You could replace the resistors (maplins) and use small jumper wires for any broken tracks on the board. Do you know why this happened, seems a little strange?
If I can't fix it I'll f**k it up so bad nobody can!!
dn808e2
Thu Apr 17, 2008 10:15 am
i took it off and when i put it back together i didn't payed attention to the exact position , it as 4 pins L shaped,
ad i 'm not sure in wich order should they be put back (one is free from the top , when i put it that way , i smelled
burn, so i took it appart again and possitioned it one slot lower, sorry for my english , it's a bit tricky to explayn, i rather take another pic
Thu Apr 17, 2008 10:17 am
The only resistor I've ever found burnt out on a speedo PCB has been associated with the feed to the econometer electronics on the SI board, and has been caused by a fault on the SI board.
Interestingly, the M3 cluster doesn't have an econometer, of course, but I've never even considered whether the electronics is there for it or no.
AFAIK, the SI board is the same, so the electronics will be on there.
Does everything work correctly, or is this just something you've noticed?
Small wattage resistors like this don't normally burn up with no reason, so I suspect this is just the result of a fault elsewhere.
dn808e2
Thu Apr 17, 2008 11:04 am
here better pic
this is how the speedo connected now, but first time a connected itt the way that firs pin was
angaiged ,now firs pin is not connected to anything
dn808e2
Thu Apr 17, 2008 11:21 am
it all working fine now , but thefirst time i connected speedo to the print board (engaiging first "top" pin) it stoped working, i took it apart,engaiged pin 2 and speedo started working
i got another q? Switch turn signal snaped, i replase it with one from the car without OBC,
the one i had , had one blue connector , but the new one doesnt have it , and OBC doesnt show fuel range, avarage miles, ets..
Thu Apr 17, 2008 1:31 pm
The blue single pole connector on the indicator stalk of a car with an OBC is simply to toggle the display through all the functions, one after another. It has nothing to do with the actual working of the OBC.
Fuel range, etc., depend on a road speed signal which originates from the speedo PCB, so your burnt out resistor and probable SI board fault are probably connected to this.
dn808e2
Thu Apr 17, 2008 10:37 pm
Thaks , much appreciated :D
78dude
Fri Apr 18, 2008 10:36 am
Why not look for a 2nd hand speedo cluster on eBay for £10.....
Fri Apr 18, 2008 10:41 am
78dude wrote:Why not look for a 2nd hand speedo cluster on eBay for £10.....
A M3 one? For £10?
dn808e2
Sat Apr 19, 2008 9:34 pm
Does enybody know what is the impedence of this resistor. and where can i buy it.
abelai
Sat Apr 19, 2008 11:44 pm
Maplins, remove it and take it with you or read the colour bars:
http://www.bcdxc.org/resistor_color_codes.htm
Sat Apr 19, 2008 11:54 pm
I think you'll find the coloured bands on this resistor are well past decoding!
No one got a speedo unit already out of a cluster?
smithy318i
Sun Apr 20, 2008 12:06 am
dn808e2 wrote:Does enybody know what is the impedence of this resistor. and where can i buy it.
33 ohms, +/-5%
