New bushes for 325i
Looking for genuine BMW parts at discounted prices? Try here!
gIzzE
Wed Apr 16, 2008 11:10 am
Can you price up the following please???
I would also like to put upgraded topmounts in, I know some people use E46 mounts, some from a 330i some from an M3, mine is a touring and I think I read that the ones from the cab are best??
So top mounts from front and rear too please.
325i touring 1988.
STABILIZER LINK 2 31351091764 front
STABILIZER RUBBER MOUNTING D=20MM 2 31351129139 anti roll bar front
RUBBER MOUNTING 2 33311129144 rear axle
STABILIZER LINK 2 33551126932 rear
STABILIZER RUBBER MOUNTING D=13,5MM 2 33551131290 anti roll bar rear
LEFT STEEL WISHBONE 1 09/1988 31121127725
RIGHT STEEL WISHBONE 1 09/1988 31121127726
M3 part
SET RUBBER MOUNTING ECCENTRIC 1 09/1987 31129061222
Also can I have a rpice for this and is it the same part for all diffs?
RUBBER MOUNTING 1 33171135242 diff mount rubber
zimmerbimmer1
BMW Parts Meister
Wed Apr 16, 2008 2:34 pm
upgraded topmounts Rear Only £33.30 (pair)
fronts are only upgradable to camber adjusting ones
STABILIZER LINK 2 31351091764 front £27.01 each
STABILIZER RUBBER MOUNTING D=20MM 2 31351129139 £7.30 each
RUBBER MOUNTING 2 33311129144 rear axle £52.39 pair
STABILIZER LINK 2 33551126932 rear £10.58 each
STABILIZER RUBBER MOUNTING D=13,5MM 2 33551131290 £2.84 each
LEFT STEEL WISHBONE 1 09/1988 31121127725 £92.81
RIGHT STEEL WISHBONE 1 09/1988 31121127726 £92.81
M3 part
SET RUBBER MOUNTING ECCENTRIC 1 09/1987 31129061222 £20.00
RUBBER MOUNTING 1 33171135242 Std £35.30
uprated one £21.34 (z3M) :eek:
gIzzE
Wed Apr 16, 2008 4:55 pm
Thank you sir!! :D
can you put me an order together for the following bits please.....
STABILIZER LINK
31351091764 front £27.01 each 2 needed
31351129139 £7.30 each 2 needed
STABILIZER LINK
33551126932 rear £10.58 each 2 needed
33551131290 £2.84 each 2 needed
M3 part
31129061222 £20.00 Pair
And a pair of standard front mounts.
Guy
