5 stud hubs
ive just bought an e28 525e(non runner).it has hartge 5 stud rims fitted.they r in real first class nick.my question is are the hubs interchangeable as ive read that the e30 m3 had e28 hubs,brakes etc.maybe someone on the zone has carried out this conversion,if so i would b very grateful for some advice.
Are looking at fitting the 5 stud wheels to your 4 stud E30??
If so I am trying exactly the same thing at the moment from an E34. I have been told there are only two sorts of hubs you can use... either the complete E30 M3 setup, or possibly an E36 Compact.
I've experimented with neither so only telling you what I've been told!!!
failing that I'm looking into having some hub adapters made... by this person on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
Wilson
Wilson
- Contact:
Hi Wilson, there are a few guys on here i`m sure would be interested in some hub adaptors myself included, please let us know if you can get some.Wilson wrote:failing that I'm looking into having some hub adapters made... by this person on ebay
Wilson
Thanks, Matt.
We have definatly agreed I will buy some of them Ԛ£149.99, however we cnt work out at the moment what the centrebore of the hubs are. I've got the following conflicting measurements of websites
www.teamruk.com
E30 - centrebore 57
E34 - centrebore 72.5
www.rochfordtyres.co.uk
E30 - centrebore 72.6
E34 - centrebore 72.6
the company that will do the adapters think the e30 centrebore is 57.1!!!
Does anyone know for definate????
Marc
www.teamruk.com
E30 - centrebore 57
Marc
i have 5stud on my e30 cab with 8/17 fronts & 9.5 rears from 850se
composites split rims i converted my cab myself in 1994 by re drilling rears & useing e36 fronts with a bush 4 stub axle by the way they do not
catch or rub
paul
catch or rub
paul
rhinoeng wrote:i have 5stud on my e30 cab with 8/17 fronts & 9.5 rears from 850se
catch or rub
paul
Do you have any pics dude? That must look amazing with those wheels!
Andy
Pasted from an email i got today...
These are built to fit a 4/100, 57.1mm center bore (all e30's) and adapt to a 5/120 (72.56mm center bore), which is a 5-lug e36/e46 pattern.
- Contact:
so you can get us some hub adaptors then???smithy318i wrote:Pasted from an email i got today...
Sorry guys, like i said earlier, I can only get one set.A1BMW325iSport wrote:so you can get us some hub adaptors then???smithy318i wrote:Pasted from an email i got today...
A guy in the USA is sending me them for $200 (Ԛ£108)
http://img.photobucket.com/albums/v210/ ... F_0017.jpg
http://img.photobucket.com/albums/v210/ ... F_0018.jpg
http://img.photobucket.com/albums/v210/ ... F_0016.jpg
edited for 56K'ers
My previous comment did not mean that I used adapters but that I used bushes for the front stub axle and for the rear wheel centre and then re-drilled the hubs. You can only do this if you have discs on the rear and by changing the front hubs to E36. If you want to know more ring me.
Paul 01253 314730
Paul 01253 314730
Sorry to dig this up from the dead, but I was told u can't make adaptors for 4x100 pcd to 5x120 pcd, due to something with one of the holes is on top of the other...quite annoying.
So what I did was get the wheels Re-PCD'd to 4x100 which can only be done if the back of the wheel is solid, and doesn't have hollow gaps between the Stud holes
