how to identify alpina engine?
mods
Sun Apr 06, 2008 4:03 pm
hi i recently bought a e30 cab alpina, how do i identify that i have a alpina engine in my car, the engine looks the same as a 325i except the heads and manifold are black. what identifying characteristics do i look for to know that its a alpina engine or not ( eg: serial number/ markings etc )? info highly appreciated anyone.
Sun Apr 06, 2008 4:10 pm
If its meant to be a C2 2.7 engine it should have a number begining with C2 stamped where the engine number is on the block.
Sun Apr 06, 2008 4:15 pm
C2 and then have the last 7 digits of the chassis number of the base car. If it's a RHD sytner conversion
If its alpina then it should have history to prove it from the service book!
4 digit stamp on the head at the front between the inlet/injector rail and rocker cover. It's next to a raised small flat section. It's very hard see and will be dirty, you need a torch really
hth
old_skool
Sun Apr 06, 2008 4:44 pm
I'm sure this is the right head stamp
Just underneath the fuel pressure regulator (ish)
old_skool
Sun Apr 06, 2008 4:53 pm
My engine number is C1/6359, and is stamped just to the right of where the original engine number should be. I've just looked at the original Sytner service book and this information tallies with that exactly.
What throws the spanner in the works is that his number has nothing to do with my chassis number and doesn't begin with C2 :mad:
It must be right as it's in the original stamped papers for the car :?
Maybe it's a prefacelift thing?
Mon Apr 07, 2008 9:23 am
old_skool_2002 wrote:My engine number is C1/6359, and is stamped just to the right of where the original engine number should be. I've just looked at the original Sytner service book and this information tallies with that exactly.
If engines and blaupunkts could talk ! :)
kidsinister
Mon Apr 07, 2008 3:58 pm
old_skool_2002 wrote:Maybe it's a prefacelift thing?
Mine is equally confusing, it doesn't match with the V5 either. It's got the four numbers in the head, though.
The dark art of Alpina identification, eh?
old_skool
Mon Apr 07, 2008 5:29 pm
:o
Don't even go there Pete!
Would Sytner themselves know the answer any more?
kidsinister
Mon Apr 07, 2008 5:41 pm
old_skool_2002 wrote:Would Sytner themselves know the answer any more?
They're cagey about giving out info these days, though I have a letter from them from the early 90s confirming the spec of mine.
Mon Apr 07, 2008 6:26 pm
Damo that picture is right on the money! RE the block thing. What i've said rings true for the facelift chariots. Only the lord knows the logic for the older stuff. Sytners made it up as they went!
Alex the V5 won't tell you anything apart from the base car model and chassis no.
kidsinister
Mon Apr 07, 2008 6:36 pm
Simon13 wrote:Alex the V5 won't tell you anything apart from the base car model and chassis no.
Indeed, but the V5 engine number starts with 225 as you'd expect, whereas the block number doesn't... :? Must have been a coincidence.
