Speedo Accuracy
Wilson
Post Tue Jun 14, 2005 8:05 am
I've always heard speedo's as standard setup tend to give a higher reading than true speed... how true is this and on average how much are they out by?
If I've now got 205/40/17's should this even it out a bit?, I suppose 40/17's are not much different to 55/15s though... I can never work these out :? :? :? !!!
smithy318i
Post Tue Jun 14, 2005 8:29 am
I don't know exactly how to work it out, but.
The larger your tyre size, the more wrong your speedo gets.
(because one revolution of the wheels = more distance)
Post Tue Jun 14, 2005 9:25 am
Nothing to do with wheel size - It's the outer diameter of the tyre that matters, not it's inner diameter.
On the correct rubber, expect the speedo to over read by about 5% or so.
This is not a design fault - it's a legal requirement that a speedo should never indicate less than your true speed, so a bit of inbuilt safety margin is required.
OBC tend to be fairly accurate ( assuming correct diameter rubber).
Wilson
Post Tue Jun 14, 2005 12:24 pm
Thanks, I'm running 40/17 tyres, standard are 55/15 tyres, would this make the overall size the same?
Jos
Post Tue Jun 14, 2005 1:20 pm
Need the width of each tyre too, the profile is a percentage of the width of the tyre, ie 40 profile is 40% of the width of the tyre so 205/40/17 would be 40% of 205mm which is 82mm.
You can compare tyre diameters here:
http://www.unixnerd.demon.co.uk/bmw_wheels.html
'94 e36 tree climber
Turbo-Brown
Boost Junkie
Post Tue Jun 14, 2005 1:41 pm
'Ere we go
205/55R15 tyres are 607mm diameter
205/40R17 are 597mm diameter
so with those, you've got even more margin of safety as each revolution equals less distance travelled :)
Jos
Post Tue Jun 14, 2005 1:47 pm
oops, should have read up the thread a bit lol, the sizes are there..
Turbo-Brown
Boost Junkie
Post Tue Jun 14, 2005 1:51 pm
If ya go to Toyo.co.uk, there's a tyre convertor thing. Quite handy really :)
Wilson
Post Tue Jun 14, 2005 2:25 pm
Well I didn't know that, profile is percentage of depth!!!!! Learn something new everyday :D
So I am now traveling 10mm, less each rev of wheel :( ... the 15's I had were the wrong size anyhow that were 195/50/15's, not 55!!!!!
Thanks Guys, just wondered really!!!!
Turbo-Brown
Boost Junkie
Post Tue Jun 14, 2005 5:04 pm
Eh? NO!
205/55R15 you travel 1906.9mm / rev
with the 205/40R17 you go 1875.5mm / rev
so 28.4mm difference :o
Wilson
Post Tue Jun 14, 2005 5:49 pm
Turbo-Brown wrote:Eh? NO!
Sorry read your last post wrong!!!! :oops:
e30-320i
Post Tue Jun 14, 2005 7:03 pm
its not your fault that your blond :? :lol:
Wilson
Post Tue Jun 14, 2005 7:06 pm
:weirdo: Your just jealous :cool:
e30-320i
Post Tue Jun 14, 2005 7:34 pm
:stupid:
