Water pump stuck
v_nitro
Wed Mar 26, 2008 3:00 pm
I got a high pitched whine from the engine last night like on the other thread here, this morning opened it up started it and the pulleys with the alternator and the water pump were not moving. took out the radiator and tried roatating each one the alternator moves freely but the water pump one (with a fan on the end?) is siezed and not moving, left it at that for now, need some advice as to whats wrong or what to do next please :)
- Val, 325i SE
TRANSPORTER
Wed Mar 26, 2008 4:15 pm
Strip out the waterpump and replace, if yoy mean the waqter pump isnt turning, they are prone to giving up the ghost ie coming away from their shafts I believe.
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
insertnamehere
Wed Mar 26, 2008 5:05 pm
That's true, I think there are (were?) two types of pump available, plastic & metal impeller. I think the metal ones were the ones that went but not too sure...
1977 Austin Allegro 1300
1992 FIAT Tipo 1600 (SOLD!!! 8O)
1977 MZ TS250/1 "supa-5"
1993 Cagiva Mito 125
1987 E30 318i (Daily driver for????)
1988 E30 325i (Not anymore, let down by seller...)
v_nitro
Wed Mar 26, 2008 10:20 pm
If i were to remove the belt that joins alternator, shaft and water pump that wouldn't miss-align anything important would it?
- Val, 325i SE
DaveD
E30Zone Wiki Specialist
Thu Mar 27, 2008 12:16 am
Its the one with the metal impeller you want, the plastic ones die!
eurocarparts list
CIRCOLI n/a 201110111 E30,E34 M20 9.87- WATER PUMP E30,E28,E34 9.87- . Z1 8.89-
£15.27
KWP n/a 201110115 E30,E34 M20 9.87- WATERPUMP
£26.46
v_nitro
Thu Mar 27, 2008 10:26 am
Sweet, thanks Dave :) Im going to assume that the more expensive one is better (metal?) and buy that.
- Val, 325i SE
DaveD
Thu Mar 27, 2008 11:32 am
I would ask them if i were you ...they are down on penistone road
v_nitro
Thu Mar 27, 2008 11:55 am
Pah didnt know that, i've ordered the parts now, way cheeper than expected too. Is it going to last?
- Val, 325i SE
hennabm
Thu Mar 27, 2008 7:12 pm
Just changed the pump on my 320 with a GSF one. Didn't notice if it was metal or plastic :cry:
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
v_nitro
Thu Mar 27, 2008 9:10 pm
Dont worry henna, they seem quite cheap (compared with 90 quid for bmw original) and should be resonable quality :) Il post back on what the KWP pump from above is like.
- Val, 325i SE
austin360
just make sure u clean the pump area well to make a good seal to the block and dont forget to put back the peg and spring to the tenshioner :)
v_nitro
Thu Mar 27, 2008 9:13 pm
Will do austin cheers :) Is it possible for the pump to leak coolant into the engine/gas leaking into the coolant if the seal is worn?
- Val, 325i SE
austin360
Thu Mar 27, 2008 9:54 pm
no what i ment is ive done a few rush job water pumps if it doesnt have a tight seal it will be hard to bleed out and the worst leak thats a lot of stripping down to do just minutes of cleaning a new gasket will be included in the kit its happened to me going to the bother of stripping it down fitting the new pump building it back up poor in the coolent in and it running down the block.O and the vis fan has a reverse tred so to take it off u go like ur tight n it
v_nitro
Sat Mar 29, 2008 6:02 pm
Got the old pump off, somehow its the back of the axle bent or maybe the impeller warped somehow, one of the sides of the impeller ground a channel into the pump casing. The kwp pump form euro parts looks alright, made of the same looking stuff as the original with a dark metal impeller, came with a gasket in the box.
- Val, 325i SE
