Post
Mon Jun 13, 2005 8:10 am
Check that key in the the lock barrel feels free to turn, and gives a positive movement (i.e.: not under any force). Also once inside the car see if the drivers side door pin when raised and lowered - operates the passenger side pin (i.e.: locks and unlocks).
It might be simple lubrication, or a worn lock mechanism?
One long term solution is to have fitted a remote locking alarm - then you can do away with key operation. Does the boot lock / unlock okay?
Regards,
pm9575
