diff speed sensor.......
justo
Sun Mar 23, 2008 6:50 pm
hi anyone need a bit of help....As my speedo gave up and all gauges fine,I decided to have a look at speed sensor ,with lots of crud around it one wire popped off ok the other came apart right on the end of the connector.is there a simple fix or will it need a re-wire job....help..
bmwe30mtech
Sun Mar 23, 2008 7:14 pm
Im not totally clear what you mean, do you mean a wire has broken? Sounds like the best option is get the 'repair kit' for this from your dealer, its a few quid. Its just a new connecter with two wires from it.
fuzzy
He who sleeps with "Gingers"
Sun Mar 23, 2008 7:19 pm
easy fix to cut back some of the old wire and connect a new piece in.
justo
Mon Mar 24, 2008 8:46 am
thanks for reply.the wire had broke.If the dealer sells a repair kit then happy days..........Thanks a lot.
Mon Mar 24, 2008 9:56 am
Skinflint alternative to the dealer kit is the yellow headlamp connector and piece of loom from a scrapper.
