We didn't re-attach the prop last week when the engine went back in so I bolted the disc onto the 'box and then tried to retract the splines to make the prop go on.
There's about 1mm of shiny spline on show so it's obviously moved at some point fairly recently, but it won't budge either way now. Haynes says not to seperate the two halves too
Is there something I need to do with the threaded collar on the front half or something?
Cheers!
