Removal of sunroof cartridge
oldbimmer
Post Fri Jan 25, 2008 7:49 am
Morning chaps..
Has anyone got an effective method for removing the sunroof cartridge???? It looks like a lot of fun... :evil:
Any tips/advice appreciated. :D
Trise30rally
Post Fri Jan 25, 2008 10:36 am
its actuall very easy, most of it is glued in.....
There are two welded tabs at the back, either side, cut those then it should pull away from the roof, then you just have to cut it away from the front........
Any questions just ask.....
Black_Potato
Post Fri Jan 25, 2008 7:35 pm
Just done mine, or 95% of it, angle grinder & goggles. As said a fair amount is glued in you just need to slice it either side of the welded tabs, carefull not to cut the roof ;)
ed325i
Post Fri Jan 25, 2008 7:56 pm
I just drilled out the spot welds and heated the glue up and pulled it out, didnt use a grinder
oldbimmer
Post Mon Jan 28, 2008 11:12 am
Thanks guys - you've given me the confidence to crack on! :cool:
northloop
Post Mon Jan 28, 2008 11:36 am
Black_Potato wrote:Just done mine, or 95% of it, angle grinder & goggles. As said a fair amount is glued in you just need to slice it either side of the welded tabs, carefull not to cut the roof ;)
Been there, seen it, done it
alan1272
Post Mon Jan 28, 2008 6:29 pm
my effective method :twisted:
ed325i
Post Mon Jan 28, 2008 7:56 pm
alan1272 wrote:my effective method :twisted:
You can just drill out the spot welds.
alan1272
Post Tue Jan 29, 2008 12:00 am
i'm afraid it's a bit late now :o: plus there's nowt more fun than a big grinder :twisted:
agreen
Post Tue Jan 29, 2008 12:05 am
alan did you pop rivet a plate over the top then ?
alan1272
Post Wed Jan 30, 2008 8:16 pm
no, i welded the panel back in on some tabs and sealed round the edge with windscreen sealant.
Lloydie38
Post Thu Jan 31, 2008 3:04 pm
Here's mine removed - what a ball ache - and it still looks cr4p but it's not for showing it's for throwing :twisted:
Image[/img]
With Hammerite...
Image[/img]
Milko
Post Thu Jan 31, 2008 6:59 pm
Can you do this with the roof lining still in the car?
90' 2dr 335i - 220bhp and 206lbft - 1/4 in 14.7 @ 97 mph *FOR SALE*
Lloydie38
Post Thu Jan 31, 2008 11:34 pm
hmmm - think it would be very tight, very limited on space..
agreen
Post Thu Jan 31, 2008 11:42 pm
ou could remove the lining do it then re fit the lining seems a little pointless to me but
saying that i just had an all plate riveted over the top of it looks good from what i have seen
hth
Brian28
Post Fri Feb 01, 2008 6:35 am
Pretty impossible with the original lining in place, wouldn't look right afterwards as the roof lining is a different shape to take account of the cassette and opening sunroof. Bin the original and fit a roof lining from a scrappie non sunroof car afterwards, should look Ok?
For sale - E30 320i racer project - sold.
Milko
Post Fri Feb 01, 2008 7:31 am
I just want to remove the sunroof panel and its mechanisam to be replaced with a cf panel bonded in place, I realise now you guys have removed everything including the metal inside the car which the sunroof slides into... correct?
agreen
Post Fri Feb 01, 2008 8:58 am
correct?
YES
ed325i
Post Fri Feb 01, 2008 9:52 am
I removed the inner skin from mine and then welded it back in.
UweM3
Post Fri Feb 01, 2008 10:08 am
ed325i wrote:I removed the inner skin from mine and then welded it back in.
ditto here. Cheapest and best looking solution IMHO.
After welding I have ground the remaining flange down a little to make it look nice. I bought some very thin and lightweight foam sheet at the Classic car show in Stoneleigh last year to glue back up instead of a roof liner.
If you want to tuck your cage up as high a spossible, there will be no room for a roof liner.
BTW insted of a grinder you can also use a sharp chisel. Loads of sparks which will settle on your screens, BEWARE!!!
ed325i
Post Fri Feb 01, 2008 3:28 pm
Or the windows of your house :cry:
UweM3
Post Fri Feb 01, 2008 7:34 pm
you don't........?
WMWNWMN
Post Wed Feb 13, 2008 8:44 am
grinding, drilling, prying, heat gun, beer. it was a fun night
my CF plug should be here any day now, damn boat ride across the atlantic takes forever some times :cry:
oldbimmer
Post Wed Feb 13, 2008 10:10 am
Thanks for all your suggestions guys...
In the end, I managed to get the cage fitted (Safety Devices B8) by cutting part of the rear section of the sunroof cartridge away, which wasn't much hassle at all. All I need to do now is seal the suroof with some sort of sealer and it's job done.. 8)
bmwe30mtech
Post Wed Feb 13, 2008 10:19 am
Im thinking about doing this soon. Unlike you guys i intend to put a new one back in! (or pay somebody else to).
Looks easier than i thought, better get the drill out.
ed325i
Post Fri Mar 14, 2008 2:16 pm
This is how mine looks now I have primed it.
nickso
Post Fri Mar 14, 2008 5:55 pm
whats it look like on the outside?
im going to remove mine in the coming months and fancy welding it.
'88 e30 328i M52 track bint.
ed325i
Post Fri Mar 14, 2008 7:35 pm
It looks like a normal sunroof from the outside.
I welded it from the inside.
nickso
Post Fri Mar 14, 2008 7:47 pm
thats what i want to do. what did you fill the hole outside with?
ed325i
Post Fri Mar 14, 2008 10:35 pm
I used Sikaflex sealant to replace the rubber seal on the outside so it looks like a normal sunroof.
nickso
Post Sat Mar 15, 2008 1:24 am
cheers for the info, i think ill do the same.
