Extra tall engine mounts
n1tr0_9
Thu Mar 13, 2008 1:48 pm
Thats what i thought, same as bump steer. Changing height of engine will alter front axle roll centre which in turn might alter toe, but only if the front suspension and steering hardpoints are crap in the first place (which i think are ok?)
UweM3
Thu Mar 13, 2008 1:49 pm
handpaper wrote: Uwe, do Gaz make the threaded tube to sit on the stub of the OE spring seat? Or does it slip on over the damper rod?
To be honest, I didn't ask - it makes very little difference to me :D
You asking me? :D
I am not using the kit, you mentioned it first and I tried to get hold of one. But they didn't know what I was talking about.
handpaper
Fri Mar 14, 2008 12:43 am
On the invoice it's listed as "ABUTMENT KIT" which suggests it's designed to sit on the OE spring seat. I'll be cutting most of that off anyway, to save weight; when the kit arrives I'll decide whether to remove the whole seat and weld the threaded tube to the strut. It may be best to leave enough to locate it, then weld :?
agreen
Fri Mar 14, 2008 10:32 am
What is the point in the above welding , cutting etc etc , seems like a big mess around to me why not just buy a proper kit . ? ? ?
Karan
Fri Mar 14, 2008 10:50 am
ive played with engine alignment etc, subframe lowering bla bla bla.. and trust me DO NOT go there. with my s38 i had to drop the subframe 20mm sop the engine would fit under the bonnet. i do believe however that the e28 m5 mounts are often used... stiffer and very slightly taller.not tall enough that they nwould warrant rasing the gbox up also to correctdriveline alignment.
as everyone else says though... get a nice sumpguard on there
handpaper
Fri Mar 14, 2008 2:03 pm
agreen wrote:What is the point in the above welding , cutting etc etc , seems like a big mess around to me why not just buy a proper kit . ? ? ?
How do you think H&R etc. make what you term "proper kit"?
Clue: there's a reason they ask for your OE front struts in exchange and charge you extra if you can't/won't supply them.
It's much cheaper to do it myself and I'll have done it myself. For many people on here, myself included, the second reason is enough by itself 8)
Karan
Fri Mar 14, 2008 2:25 pm
its not that big mess around and in the process you learn a lot about suspension
agreen
Fri Mar 14, 2008 2:55 pm
whatever i gues , i would rather pay dave at gaz to do it for me but thats just me i gues 8)
Karan are you not getting a GAZ kit ?
Karan
Fri Mar 14, 2008 4:06 pm
i will in the nr future, however my silvia needs some love and attention at the moment as the trackday at bedford warped my front discs... steering rack bushes are worn too. basically funds not allowing at the moment. Will have to live with a soft e30 for a while. its my road car and i dont really rag it around so i have yet to tackle the brakes and suspension on it.
would rather get my silvia ready to go out on track at the moment to be honest
UweM3
Fri Mar 14, 2008 8:36 pm
agreen wrote:whatever i gues , i would rather pay dave at gaz to do it for me but thats just me i gues 8)
the big difference between a GAZ kit and the DIY solution is the lack of damping adjustment the GAZ offers. Longterm the GAZ is the better investment, they can be rebuild, revalved for very little money and modified to your requirements. Not saying Bilstein/Koni can't, but it's a lot more hassle finding somebody to do the job.
handpaper
Tue Mar 18, 2008 2:07 am
For all those watching for it, the build thread is now HERE
