got a 325 manual with lsd track day car
was gonna tow it to track days on a dolly will this be ok for the box etc
towing my 325
TOURINGDADDY
Yes it is ok but if ur still not happy then lift the rear wheels
Jesus325iTouring
- Frog freak !
I've towed just about everything you can tow with my 325 and have never had a problem,the only thing I would complain about is having to change gear to much,the E30 gearbox isn't really designed for towing in my opinion,but as long as you don't mind changing gear to much,you won't get any problems.
As for your track car with LSD,this should make no difference,it's only auto box cars you shouldn't tow.
320Touring
yeah towing with a dolly should be fine-wont do any damage
could also use a towing bar (Ԛ£30) instead and have 4 wheels on the ground...
bullitt
And someone to steer it!!320Touring wrote: use a towing bar (Ԛ£30) instead and have 4 wheels on the ground...
Ant
- Retired Team Member
Towing a car equipeed with an LSD is a big NO, by the time you get where you're going the clutch pack will be scrap in the diff dude
Please dont do it !
Please dont do it !
Email FTW
320Touring
could put the rear wheels on the dolly and leave the steering lock on?ant wrote:Towing a car equipeed with an LSD is a big NO, by the time you get where you're going the clutch pack will be scrap in the diff dude
Please dont do it !
