Rear diff hanger reinforcements
oldroydsr4
Post Sun Mar 02, 2008 8:22 pm
Hi all
Just after a bit of info on reinforcing the rear diff hanger , as iv seen big power e30's pull them off the shell :eek: and after so much time and money invested into my build don't want this to happen.
What are the big power e30's using, or are you running on hope?
Iv read somewhere about using an e36 diff back plate, which has 2 pick up points.
My shell is now at the point of bolting the rear suspension on so now is the time to do the work
Any help is welcome.
cheers
march109
Post Sun Mar 02, 2008 8:30 pm
There isn't anywhere for the second mount to bolt if your using a e36 diff plate.
The Z3M diff cover has a stronger mounting point! how much power you gonna have when your done?
oldroydsr4
Post Sun Mar 02, 2008 8:42 pm
I know that matey, but I have access to all tools required for fabrication. etc.
Z3m isn't an option because its the hanger that snaps not the diff plate, ive already installed the z3m bush but if i have the option to make it unbreakable i think i should take it. Also i believe BMW had a few problems with z3m's breaking diff hangers too.
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sun Mar 02, 2008 8:43 pm
you can make an e28 m535 big case diff fit, the swedish boys use them for big power
oldroydsr4
Post Sun Mar 02, 2008 8:44 pm
whats involved with that, any pics
Colonel Sanders
Post Sun Mar 02, 2008 8:50 pm
not sure exactly whats involved but its all on ppf website, just cant read swedish, sure if you asked on there they will tell you
Andy335Touring
Post Sun Mar 02, 2008 8:55 pm
You are best off either reinforcing the diff bracket and where it attaches to the floor with some thicker metal or cut the braket off and weld a base plate thats bigger than the where the bracket attaches to spread the load then make a new bracket and weld it to the base plate.
It would be a lot easier just to reinforce the original, i've seen E30 with rollcages that have a pick up point that connects up to a diff bracket base plate but this is over kill on a road car.
oldroydsr4
Post Sun Mar 02, 2008 9:08 pm
Rossle :Have you got a link?
and i'll try and find a translator
The car is only for trackuse and my cage is only a 6pt but i might have a think.
I think ant adds another skin and seam weld the bracket, but i've been on realoem and can't find the part number for the plate.
james3320
Post Sun Mar 02, 2008 9:13 pm
just finished rebuilding the backend of my touring, i welded a plated over the top of the carrier that holds the diff,(where the four bolts go through) to strenghten this the welded angle iron along the car where the diff mount
bolts up too.. will try and get some pics
oldroydsr4
Post Sun Mar 02, 2008 9:20 pm
Sounds good, a few pics would be welcome.
Colonel Sanders
Post Sun Mar 02, 2008 9:21 pm
http://www.pure-pf.com/phpBB2/viewforum.php?f=1
start a thread mate, they all talk english, i have got some very interesting and helpful imformation from them.. :D
oldroydsr4
Post Sun Mar 02, 2008 9:55 pm
Cheers mate
here is the original thread that got me thinking
http://www.e30zone.net/modules.php?name ... diff+mount
scary sh*t
oldroydsr4
Post Mon Mar 03, 2008 7:46 pm
does any one know if the e36 diff plate fits straight onto the e30 lsd?
kevo
Post Mon Mar 03, 2008 10:13 pm
http://www.bmw-rallying.co.uk/forum/vie ... &start=120
yes it does as long as you have a 188mm cwp size case (325), heres a photo of mine
Kev
oldroydsr4
Post Mon Mar 03, 2008 10:51 pm
Cheers, i cant see your pic tho but ive registered and waiting for the account to be activated.
Have you also got pics of the pick up point assembly?
Karan
Post Tue Mar 04, 2008 8:44 pm
with the s38 in my car and almost 10k miles since conversion including hard launches and some drifting mine has been fine so far... when i strip it again and it goes for a respray and maybe a cage, i think i will just mig up some plate over where it joins the floor and then triangulate and strengthen the original bracket onto this plate.
as my suspension isnt extremely hard and subframe and diff bushings are stock this reduces shock on mountings, polybushes or solid ally ones might destroy the diff mounting as it does look weak!
other options include doing the above but triangulating down from the rear turrets or a cage i guess?
oldroydsr4
Post Tue Mar 04, 2008 8:55 pm
Just to show you the work that Kevo has done.
I'm planning on copying this. It really does look unbreakable and if you already doining some welding ,a little more fabrication isn't going to matter.
standard e36 diff.
bracket
Welded to shell
HairyScreech
Post Tue Mar 04, 2008 11:32 pm
i was going to sugest that the best way would be to get under an e36 and take the whole diff hanger off, then simply a case of joining to your chassis, which is easyer that it sounds.
with the twin mount you will be pushing up on the right mount and pulling down on the left, this would mean it would be next to imposible for the diff to pull the channel down as it would be trying to turn around the right hand mount instead of just pulling downwards. if that makes any sense.
oldroydsr4
Post Wed Mar 05, 2008 5:54 pm
Been to fab bmw today and got myself an e36 rear diff cover £15.
time to get on it :cool:
Colonel Sanders
Post Wed Mar 05, 2008 5:58 pm
let me know how it goes mate, as i could be interested in doin this myself instead of an m535 diff.. :)
Karan
Post Wed Mar 05, 2008 6:00 pm
anyone got info on how to fit a larger diff like from an e28?
mattG
Nice work kevo :D
Does look like a sensible upgrade, how much are the e36 diff covers?
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
fowler
Boost Junkie
Post Wed Mar 05, 2008 6:06 pm
no point as even if you do use the e36 diff cover it can still pull away as the beam is the ONLY rear Stabilsing bar at the rear best thi would to be develop some anti tramp device from hard launches
EX A-Tech Workshop bitch !!!
gone but not forgotten
FormerMember
Post Wed Mar 05, 2008 6:15 pm
I'd do it this way. (these pictures are on this topic on PPF: http://www.pure-pf.com/phpBB2/viewtopic ... c&start=95 )
5mm aluminium-plate (diff is from E28 535)
Still, what's the point in this operation? You need way over 500hp before you've problems with diff ripping off...
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Colonel Sanders
Post Wed Mar 05, 2008 6:16 pm
ppf make half shafts that can twist 1 and a quater times for hard launches, taking some of the force away from the diff
mattG
Post Wed Mar 05, 2008 7:43 pm
sorry OT, but how much power can the e28 535i diff take & are the e34 diffs any good?
(\__/)
E21 turbo
Colonel Sanders
Post Wed Mar 05, 2008 8:09 pm
m535 diffs have seen over 800hp
mattG
Post Wed Mar 05, 2008 8:19 pm
rossle wrote:m535 diffs have seen over 800hp
:eek:
e34?
(\__/)
E21 turbo
Colonel Sanders
Post Wed Mar 05, 2008 8:28 pm
e28
mattG
Post Wed Mar 05, 2008 8:33 pm
Sorry I reliased 800bhp for the e28, how much power can the e34 diffs take?
(\__/)
E21 turbo
Colonel Sanders
Post Wed Mar 05, 2008 8:50 pm
oh, i dunno mate? if its large case, around the same? depends how you abuse it :)
FormerMember
Post Wed Mar 05, 2008 8:56 pm
Normal E34 diff can't take as much as E28 diffs, expect E34 M5 diff which has handled over 1000hp in vsmotors M5 (I think the diff is stock, not sure though). ( www.vsmotor.no )
Anyways, E28 525 diff is "the diff", most durable and toughest diff BMW has ever made.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
jaistanley
Post Wed Mar 05, 2008 10:47 pm
I like the look of the E36 diff cover mod.. More than enough for the kind of torque most of us are generating I'd say?
Might consider doing the same myself. :cool: ... Pehaps later on though. Need to get the stupid thing driving first. It's be nice to combine that mod with a triangulation to the rear 'strut towers'; though in practice, without a cage I can't see that making a huge difference unless you have turreted the rear and are running coilover type shocks.
Cool none the less.
Keep us posted!
Jai
oldroydsr4
Post Thu Mar 06, 2008 6:11 pm
I don't really agree, also the beam can be reinforced aswell with out much bother, i.e weld a thicker plate where it bolts, same as james3320 has done with his m50 turbo.
Any how the proof is in the pudding and i can't find any links of e36 carries being distroyed
e21Jason
Post Thu Mar 06, 2008 7:24 pm
Intersting work on the e36 dual mount from a conversion on s14.net you make need to swap the trigger wheel and speedo sensor around
Jason
