it starts first crank struggles to idle at 400 rpm then after a while it picks up and runs at a steady 900 rpm
ive tried different idle control vales different afm`s different tps switches
no leaks in pipes if i put the air con on the revs stays the same
ive change the thermo sensor blue one next to temp sensor nothing choke is not coming backjavascript:emoticon('
')Cry
is there something im ovelooking
