coolant leak
- Aleksandar
Not hard with RHD. Get under there and remove a couple of screws and remove the heater pipes under the bonnet.You'll have to remove either the heater valve and that little plastic pipe or remove four nuts on the bulkhead holding the big black heater case. I found removing the valve&pipes very easy WITH the right tools. Returning the heater console back in place can be a problem if you're working alone and can be hard.
After all of this is done just slide it out.
- Brianmoooore
Sure it's coolant, and not rainwater finding its way in because of blocked scuttle drains?
If it is coolant, then the chances are it's the electric valve, rather than the matrix, although leaking matrices aren't unknown.
Make sure the coolant pressure cap has been changed under recall! There are STILL E30s around with original caps - the touring I bought yesterday, for one!
- Brianmoooore
You can tell if it's coolant by tasting it!
- Aleksandar
Probably valve then if it's ONLY on the passenger side but could be any of the two. You can smell the coolant unlike rainwater, the easiest way to check.
- Brianmoooore
Another member to add to my list of " e30zone members never to buy cars from".
- Aleksandar
A new engine won't renew you heater matrix/valve.
I HOPE YOU DONT MIND ME HI-JACKING THIS THREAD SLIGHTLY!
the other day i was in a traffic jam in my 325i with the heating on and the fan on 2. . . all of a sudden steam fired out of all 4 heater vents and totaly filled my car up. i switched the car off and dived out the car like sh1t of a shovel! when i got out there was coolant p*ssin out all over the floor but my footwells remained dry. . . can anyone tell me what this might be and how to fix it???
thanks!
thanks!
