B10 Alpina wheels fit E36???
BIGJO
Post Fri Feb 29, 2008 8:56 pm
Hi,
Just wondering if anyone knows whether the B10 Alpina alloys fit the E36?
Kind regards.
Alpina99
Post Fri Feb 29, 2008 10:07 pm
Although both cars have the same 5 x 120 PCD I think the E36 is 35 to 45 offset & the E34 is 15 to 25 offset so there may be problems with fitting.
320ise
Post Sat Mar 01, 2008 4:43 pm
I have tried this with e34 alpina's they do fit the e36 but seem to stick out of the arches and would rub excessivly.
BIGJO
Post Sat Mar 01, 2008 5:39 pm
Okay thanks for the infomation guys :)
oze30
Post Sat Mar 01, 2008 7:37 pm
Yes, But you'd be looking at the euro look!
BIGJO
Post Sat Mar 01, 2008 9:47 pm
Wider arches etc?
oze30
Post Sat Mar 01, 2008 10:34 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=019
It's a bit exagerated as these are et13's, but you get the idea.
Possibly may need wider arches, or just some serious rolling!!
BIGJO
Post Sat Mar 01, 2008 11:33 pm
LOL!
I'll see what the bodyshop reckons.
Thanks for your time fella.
BIGJO
Post Sun Mar 02, 2008 11:10 pm
Anyone know how wide the wheels are on the rear of these B10 wheels? Is it 8J front & 9J rear?
Kind regards.
oze30
Post Sun Mar 02, 2008 11:45 pm
I'd say 9 ish.. could be 9.5
BIGJO
Post Sun Mar 02, 2008 11:46 pm
Okay thanks fella. I have a set of these B10 wheels but not sure. They are bloody wide though!
Jeepster
Post Wed Mar 12, 2008 4:08 pm
They will go on, if the car is lowered that can cause issues, but you can forget it if your going with the B10 tyre size, you will need a fair stretch to be able to do it.
georob
Post Wed Mar 12, 2008 4:37 pm
9.5J wide iirc.
Def wont fit nicely, diff offset on the e34 rims, more hassle than worth imo
Good luck though
Jeepster
Post Fri Mar 14, 2008 8:35 am
They will fit nicely, if you like the euro look. 215/ or 225/40/17's and you will have them on, a set of Gaz (rebound adjustable) coilovers for cheap money and you will have a car with a trick stance.
