a rather clever reply from Uwem3 showed a tried and tested idea of using . . . . .
ICE HOCKEY PUCKS yes thats ice hockey pucks, they re glued together and then 2 3mm s/s plates one one the top and one on the bottom and the the middle puck before gluing will be machined down to the correct size for the engine mount !! then a hole is drilled threw the middle and fastened to the chasis using m10 high tensile bolt and double nutted at the top ! there is a fair bit of work but i have found a company to do it if the interest is there
On the thread there were lots of people saying the pucks were difficult to get hold of etc and finding out the height of their engine mounts would be a pain on a daily driver ,
After much searching i have managed to find a surplier that is ready to go for these pucks i have someone who can make the plates to the correct size and they wil be high quallity laser cut jobbies ! and i have the bots and nuts also ready to go , aswell as a machine shop to drill and machine the pucks down !
now i am offering three things if the interest is there
1 ) i can just surplie the pucks needed for the job , you source your own bolt, nuts and plates and also get the middle on lathed down
2)i surplie the bolts the nuts the pucks and you get the puck machined down
3 ) i send you the bolts the pucks glued together machined down holes drilled plates atached and ready to fit , and it will be made to the correct height for your engine . ( the best i think )
i have been in a car with these i and i think they are great not solid to transfer to much vibration but hard enough to do a bloody good job !
uwe m3 has run these with others for 3 ring trips and several uk track days and he says his engine moves nill
THESE WILL NOT BE BODGED TOGETHER CRAP THEY WILL BE A CHEAPER SOLUTION TO GETTING A GREAT ENGINE MOUNT IMO
let me know make lists etc of who is interested in what and we will go from there , i have a the bits redy for this and have put alot of effort in and i have even ordered some engine mounts for the m10,m20,m42,s14 from bmw to measure the height so they are exactlly right please let me know as i say i am ready to go the more they are thecheaper they are !!!
thanks arron
