hi, as above how hard is it to put a 325i engine in a 320i? i have done a fue engine swaps but never ever worked on a bmw before.
thanks for any help.
how hard is it?
thanks for the help. how much do the engines go for £Â£Ã‚£?
regards
Matt
regards
Matt
HairyScreech
200 ish for an ok engine and 300+ for one with a known history.
Hi Chris-w
Just done exactly this only 2 weeks ago. As has already been said, straight swop. The only difference we found was the prop is slightly different, the 325 is slighty shorter (maybe someone will confirm that?). You will need an ecu ( i got one from ebay for £20) and the airflow meter for the 325 (should come with the engine.
Took an 8 hour days worth of work from taking the 320 lump out and have the car running with 325 power, that includes a few tea breaks
If you have done other engine swops, this is a doddle !
Good luck.
Good luck.
is the box the same? i.e ratios and top speed?
regardes
Matt
regardes
Matt
