clutch judder
keith52
Post Wed Jun 08, 2005 10:27 pm
As title really , prettty severe from moving off in ist hasn't been a problem before but the car has only just been put back on the road after 2 years , any suggestions , Obvoius points are the mountings but are faults on them easy to spot and if so how much approx to change Cheers keith
Templ8e30
Post Thu Jun 09, 2005 2:26 pm
Clutch judder is a pretty common fault with the e30, my 320i did it when I first bought it as that had been sat on a drive for 6 months prior to me buying it.
In fact when the 2.7 gets really hot the new clutch can start to judder slightly when slipping it in traffic :(
I'd just keep driving it for a while to see if it calms down !
Cheers,
Iain T
2007 Mazda 6 2.0 estate
keith52
Post Thu Jun 09, 2005 5:10 pm
Thanks Iain , yes my previous 320 used to do it when hot but this is from cold so it may be a mounting on it's way out which i'd prefer it to be rather than the plate , just wondered if there a any obvious signs to look for on the mountings Cheers Keith
