m30 conversion progress and questions
johnl320
Post Sat Feb 23, 2008 8:58 pm
You sorted this yet beefy??
john
beefy
Post Sat Feb 23, 2008 9:54 pm
yeah still no further i a bit lost with it.
Also not sure what to do about the gap in the gear linkage were it meets the shifter.
Also not sure exactly what to do with the props i got one of the 5 series and one of the 318is just dont know were and what needs cutting.
E30 M30 Mounts £100 pm me for info.
johnl320
Post Sat Feb 23, 2008 10:47 pm
beefy wrote:yeah still no further i a bit lost with it.
I cut off the drive flange from both ( gearbox end ) and welded on the 5 series bit to the rest of the e30 bit. Make sure the length is correct before cutting the e30 one especially the front section from the gearbox to the prop centre bearing because that section is non adjustable.
My gear linkage was the perfect length, but thats because mines a dogleg box with a pressed steel gear stick mount. Pure luck rather than judgment.
john
beefy
Post Sat Feb 23, 2008 11:11 pm
so with the prop its only the very fronts that need to be cut and you only use a small bit of the 5 prop onto the e30 prop. And make sure the e30 centre bearing lines up with the holes in the car floor.
Its not the length of the gear linkage thats the prob its were the linkage meets the shifter you know that pin on the end of the linkage were the plastic bush of the shifter goes through and you put the yellow plastic washers go on and the circlip thing goes on there is about a 5mm gap each side. Is this normal because i dont think it is. Its either ive got the linkage the wrong way round ie gearbox end on shifter end but either way its still not right. Maybe pics will help.
johnl320
Post Sat Feb 23, 2008 11:28 pm
Thats what I've done with my prop, all e30 except the flange at the front.
with regards to the gear linkage, why not make up some spacers to go on each side to take up the excess
john
jaffro
Post Sun Feb 24, 2008 12:33 pm
ive got spare props here if u need them :P
Theo
Post Sun Feb 24, 2008 12:47 pm
Beefy, I think Toby_Unna still has his m3 prop which he's selling. Well worth the money, and saves time messing about with chopping and welding. If I were you i'd snap it up straight away.
beefy
Post Sun Feb 24, 2008 1:05 pm
ill send him a pm cheers
gareth
Post Sun Feb 24, 2008 1:43 pm
i think there was a revision on the linkage (knuckle) on the gearbox. they were wearing so it was changed and made wider. you might have an old knuckle joint with a newer linkage, maybe! pics would help! :D
beefy
Post Tue Feb 26, 2008 8:23 pm
i got a single temp courtesy of johnl320.
I just have a few questions about the wiring of it.
The fan pulls 8 amps i have a 30 amp will this be ok, and is it a 10 amp fuse i will need to fit between the fan and the relay.
Brianmoore do you have any suggestions regarding the engine not stopping problem.
Post Tue Feb 26, 2008 9:04 pm
gareth wrote:i think there was a revision on the linkage (knuckle) on the gearbox. they were wearing so it was changed and made wider. you might have an old knuckle joint with a newer linkage, maybe! pics would help! :D
Correct, and almost certainly. Buy a new joint to go on the gearbox shift rod.
Post Tue Feb 26, 2008 9:08 pm
beefy wrote:i got a single temp courtesy of johnl320.
8A doesn't sound a lot for a fan. My (BMW 5 series aircon) one draws around 20A.
You have a 30A what?
Fuse will need to be 15A or even 20A, to deal with the starting current of the motor.
beefy
Post Tue Feb 26, 2008 9:29 pm
sorry 30 amp relay.
Do i need to think about the wise size too. Think the wire on the fan is about 1.5mm2.
Post Tue Feb 26, 2008 10:12 pm
30A relay is more than adequate.
1.0mm2 or 1.5mm2 sounds about right.
gareth
Post Tue Feb 26, 2008 10:50 pm
brian, a computer tip for you... hold down ALT and type 0178 to get this: ²
1.0mm² or 1.2mm²
0181 = µ
0176 = °
0216 = ÃËa
hehe, i know (now knew) something you don't! that'll be a first! :D
beefy
Post Wed Feb 27, 2008 7:15 pm
think i may be a bit closer to sorting this engine not stopping problem.
I get a circuit between the green ignition wire and the blue altenator wire. But when i unplug the obc control module it breaks the circuit. The plug i unplug is the 4 pin one with green, green/red, brown and brown/yellow.
It was only after i fitted the obc that the problem started.
Is the control module the fault or is it something else?
Ziggy
Post Wed Feb 27, 2008 7:20 pm
beefy
Post Wed Feb 27, 2008 8:26 pm
cheers ziggy ill stick the control moulde in the bin!
taldo50
Post Thu Feb 28, 2008 11:35 pm
hey beefy, im also from teesside, guisbrough specifically, and im thinking about this conversion, really looking forward to hearing the results of yours!!!
Post Thu Feb 28, 2008 11:58 pm
beefy wrote:It was only after i fitted the obc that the problem started.
Now you tell us!
beefy
Post Fri Feb 29, 2008 6:55 am
taldo ya welcome to come round and have a look at mine if you want.
taldo50
Post Fri Feb 29, 2008 11:04 am
nice one beefy, where abouts are you? id love to pick your brain!!!
ric325i
Post Fri Feb 29, 2008 11:16 am
taldo why dont you just buy Gall's 335i?
its in the for sale section. save you lots of work.
beefy
Post Fri Feb 29, 2008 11:26 am
stockton on tees m8.
taldo50
Post Fri Feb 29, 2008 11:35 am
ric325i wrote:taldo why dont you just buy Gall's 335i?
doing the work is half the fun and the sense of acheivment would be rewarding!!!
jaffro
Post Fri Feb 29, 2008 11:40 am
doing the work is half the fun and the sense of acheivment would be rewarding!!![/quote]
exactly as ive just done it a it makes you smile when you hear it for first time
beefy
Post Sun May 25, 2008 10:32 pm
Drove the car for the first time today and there is a few probs with it.
The clutch is slipping i think this only because when i drive with my foot only resting on the pedal because the biting point is so high. Does it mean the clutch is on its way out. It did seem ok in the e34 tho. Could it not be bleed right or does that cause the opposite problem with the bite being low and the pedal light as it is really heavy now.
Oil leak where sump meets bell housing could this be the cause of the problem with the clutch? Not sure how to tell if it is engine oil or clutch fluid.
Exhaust blowing a bit which is easy fixed.
Because of these problems i didnt drive the car much and didnt really get the power down. But you can tell its there very torquey i tried pulling off in 4th to check the clutch and it was happy to do so i had to pull off in 5th to stall it.
beefy
Post Sun May 25, 2008 10:35 pm
Also lots of pressure in the coolant system hope the headgasket hasnt gone or could this also be because it isnt bleed right.
DRIFTBOY
Post Mon May 26, 2008 1:21 am
Oil on the cluctch friction plate could easily cause the clutch to slip.
My first check would be the tightness of the sump to block bolts, it can cause oil to get into the clutch housing.
E30s with M30 engines are a bit of an arse to bleed the coolant on, just make sure you get the expansion tank as high as possible and regularly chack what comes out of the bleed screw on the thermostat housing by cracking off the bleed screw regularly. Once a stwady stream with no fizzy bubbles comes out of there, the heater blows hot and the temperature guage is behaving then all should be good!
turkey
Post Thu May 29, 2008 8:12 pm
Hello people,
Put the M30 engine my E30 the other weekend, (cheers for the mounts beefy, perfect, will get pictures up soon) just got a quick question about the AFM, the box with AFM embossed on it separate to the engine will i need this as i left it in the donor car which is now long gone :( if i do need this does it just plug into some of the extra wires by the ECU? Also do i need the connecters by the ECU wiring as there are quite a few plugs with no where to go!?!?
Cheers for your help,
Shaun.
clutchsnappy
Post Tue Jul 22, 2008 12:26 pm
If its the AFM your talking about, yes you do need it! The air box (that has the filter in it) you can do without just purchace a pod air filter for now.
I too am interested in what all the plugs around the ecu plug is for, my engine was auto and I'm using the auto wiring harness, so I guess it complicates things abit more.
Anyone got a pin out for the c101 plug for the 89 e34 535i auto engine harness?
turkey
Post Tue Jul 22, 2008 9:00 pm
Cheers for the reply, but it's all done now and on the road :D
As for the plugs, none of them i needed so just tied them up ad hid them away, just needed to live up wires for ecu and fuel pump which i put on a separate switch, not too mch to change at all.
Will get round to putting some pictures up one of these days....
Post Tue Jul 29, 2008 9:40 pm
Beefy PM SENT! for mounts :cool:
Post Wed Jul 30, 2008 9:26 pm
pm sent again beefy :cool:
