m30 probs(no more)
jaffro
Post Thu Feb 14, 2008 1:29 pm
tried a new 1 same prob :cry:
Post Thu Feb 14, 2008 1:40 pm
What are you bridging to get it working? It's possible you may have a blown fuse and even ignition switches sometimes play up. Does the car have an immobiliser fitted?
jaffro
Post Thu Feb 14, 2008 1:44 pm
ive just read a thread a i think is because my starter has packed up again so pump wont run unless engine turning which it isnt :P
Post Thu Feb 14, 2008 1:45 pm
Immobiliser on the blink? I notice your cab has that magnetic key lock on the driver's door...
jaffro
Post Thu Feb 14, 2008 1:58 pm
immobiliser was took off. il just have 2 wait for new starter a go from there. thanks anyway :P
Post Thu Feb 14, 2008 1:59 pm
No worries, good luck 8)
jaffro
Post Thu Feb 14, 2008 2:00 pm
Speedtouch wrote:No worries, good luck 8)
i definatly need it lol :cry:
Templ8e30
Post Thu Feb 14, 2008 4:13 pm
The fuel pump will run when the relay socket is bridged, even with the ignition off, that's normal.
Try giving the starter motor solenoid a sharp tap, the solenoid is probably sticking.
I bet the starter is a bitch to get at now it's in the car :?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Chris-W
Post Thu Feb 14, 2008 4:43 pm
All sorted apparently, as per phonecall just now.
Congrats Carl! :clap:
jaffro
Post Thu Feb 14, 2008 4:45 pm
cheers chris i got huge smile on my face again now. :P :P :P
jaffro
Post Thu Feb 21, 2008 8:02 pm
the cab will be up for sale soon so if any1 has any tech 2 rear bumpers fiberglass is ok a bits im willing to swap for the nitrous wet kit thats also in the for sale section :cry:
jaffro
Post Sun Feb 24, 2008 6:41 pm
got my exhaust on and now there seems 2 be a knocking on bottom end of the engine that goes away when warmed up anybody any ideas ?? also need another rad now :cry: :cry:
