No more b***ocks about weight balance
- Yaninnya
- Contact:
I found these informations in german Auto Motor und Sport magazine so very respectable source:
Model - weight balance - weight - month/year of the test
316i (M40) - 52.0/48.0 % - 1122 kg - (09/1988)
318i (M10) - 52.7/47.3 % - 1028 kg - (03/1983)
318i (M40) - 52.4/47.6 % - 1093 kg - (10/1987)
318i Cabrio (M40) - 49.6/50.4 % - 1269 kg - (08/1991)
318iS - 53.3/46.7 % - 1132 kg - (08/1989)
320i - 54.8/45.2 % - 1084 kg - (01/1983)
320i Baur - 51.4/48.6 % - 1148 kg - (06/1983)
320iS - 52.1/47.9 % - 1218 kg - (02/1989)
323i (139 PS) - 54.0/46.0 % - 1173 kg - (02/1983)
325i - 52.4/47.6 % - 1209 kg - (10/1985)
325i Touring - 51.0/49.0 % - 1297 kg - (09/1988)
M3 - 52.2/47.8 % - 1237 kg - (07/1986)
324d - 53.0/47.0 % - 1230 kg - (09/1985)
Thats their own measurements from tests, not BMW data.
Jan
Jan
treeseries
i dont see the 325is there? i bet with all that kit it weighs more
currently without a BMW ðŸ˜
I wondered the same regarding the 316i and 318i.1an wrote:how can a 318 weigh less that a 316 its exactly the same engine.
and a 325 is apparently over 100kg heavyer than a 320?
More understandable with the 325i though - bigger diff, bigger gearbox, ABS setup, oil cooler, bigger brakes, bigger front legs/shocks, rear ARB sure there are more factors.
But look at the year they tested the 320i, 1983. Probably a poverty spec so no power steering, electric windows. Could also have been a two door and the 4 pots four doors.
With regards to the 325/320 weight difference, 100kgs is a bit excessive but take into account smaller diff, no rear ARB, smaller front struts, battery in boot kit ( have you felt the weight or had to post one?), oil cooler. All starts to add up, but not to 100kgs.
Too many variables on the spec sheet to be an accurate test IMO
john
john
when you put it like that it makes sense i suppose but a tad excessive.johnl320 wrote:But look at the year they tested the 320i, 1983. Probably a poverty spec so no power steering, electric windows. Could also have been a two door and the 4 pots four doors.
john
Rosc0PColtrane
No, you fecked that up by sitting in one and eating burgers. It threw every touring on the planet out of kilter, such was the magnitude of your atrocity!Gortour wrote:And I always thought the Touring was more balanced due to the extra weight at the back end... ?
Good to hear that a 325i is lighter than an M3
snoops
- Major Helmet
iirc there were only 2 doors available in 1983 and most didn't have ABS or PASjohnl320 wrote:But look at the year they tested the 320i, 1983. Probably a poverty spec so no power steering, electric windows. Could also have been a two door and the 4 pots four doors.
john
so an M40 touring would be about 50/50 then, noting one isn't listed thereYaninnya wrote:I found these informations in german Auto Motor und Sport magazine so very respectable source:
Jan
Isn't that what i said??snoops wrote:iirc there were only 2 doors available in 1983 and most didn't have ABS or PASjohnl320 wrote:But look at the year they tested the 320i, 1983. Probably a poverty spec so no power steering, electric windows. Could also have been a two door and the 4 pots four doors.
john
march109
- Contact:
hahaha no more boll*cks my hairy arse
Firstly is the front/rear or rear/front I kno which s more likely but as it doesn't specify hardly scientific.
Secondly what optional extras were fitted? if any? option spec of tested cars could be wildly different.
And Finally the 325i Sport has the battery which weight in excess of 10kg in the rear, (given the figures for the 325i 15kg = (100/1209)*10 = 0.83% does that make the sport closer to 51.57/48.43? what about the extra cables? how much fuel ere these cars loaded with? what interior did they have?
You'd have to be a complete penis to think all e30's have more weight over the rear wheels than the front.Firstly is the front/rear or rear/front I kno which s more likely but as it doesn't specify hardly scientific.
BTW, all 2 and 4 door 325i saloons had the battery in the boot.
march109
- Contact:
My point incase you missed it, you can hardly call it scientific proof when the conditions for the experiment used to define and calculate the data has not been specified. We don't even know if the same measurement device as used on each vehicle, now you post a dyno graph and you'll get the 'that car would make less power on a different dyno' brigade jump right on you.
The specifications of the vehicles, fuel load, even number of doors on some results are unknown to us.
You have me on the battery issue, since I've never had anything other than a sport and an is. However I have a lard arse thats probably even worse for mass (which is the correct term) distribution!
I didn't miss any of your points (all of which have already been mentioned in this thread)
Your initial point is undeniably stupid, the German writers probably presume that their readership have a grain of common sense...
- Yaninnya
- Contact:
Sorry mate, but english is not my first language. I'm doing my best.march109 wrote:for mass (which is the correct term) distribution!
Jan
P.S. I can translate the specification of tested cars, but it will take some time.
march109
- Contact:
no worries dude I understand that, mass is just the correct scientific term for weight, I was being scientifically pedantic a fact missed by some who do speak english as a first language so don't worry.
Quick Wiki explanation:
In modern scientific usage, weight and mass are fundamentally different quantities: mass is an intrinsic property of matter, whereas weight is a force that results from the action of gravity on matter: it measures how strongly gravity pulls on that matter.
It is important in this distinction because we are calculating mass balance and therefore need to locate the center of gravity of an object (although if the gravitation field is uniform, the center of gravity will coincide with the center of mass).
And mass is in fact measured in Kg, weight is a function of mass under earths (or another) gravitational force and is therefore measured in N (newtons) or Kg m/s^-1.
But your usage of the ord weight was indeed correct in common english language if not 100% scientifically correct.
What? You mean a tow bar?And I always thought the Touring was more balanced due to the extra weight at the back end... ?
