Engine Rebuild Cost??
Chris
Post Wed Feb 20, 2008 12:48 am
Hey guys, i know it's a bit of a vague question but how much do you learned folk reckon it would cost, in parts, to fully rebuild and old M30 B35?
Assuming of course that i did all the spannering myself. With decent quality parts (maybe not BMW originals, but known brands of reasonable repute)
And anyone want to hazard a guess as to the same for an M5 engine (3.5ish twin cam(dont know the designation)(M1 engine))
Chris
Turbo-Brown
Boost Junkie
Post Wed Feb 20, 2008 7:42 am
It cost me about a grand to rebuild an M20 to standard spec which included new oil pump, bearings, gaskets and seals, cylinder hone, new valve guides.
No new pistons etc were used but it still cost a lot!
Chris
Post Wed Feb 20, 2008 2:41 pm
:eek:
Hmm, might be needing a rethink.
ed325i
Post Wed Feb 20, 2008 3:10 pm
I say about a £1000.
Martinaston
Post Wed Feb 20, 2008 4:28 pm
As they say "buy cheap, buy often".
Done properly your looking at a grand minimum.
There is NO nucleus.
Post Wed Feb 20, 2008 6:11 pm
Grand easy, I spent nearly £400 on genuine shells and oem rings, if id bought genuine rings it would be closer to £500
e21Jason
Post Wed Feb 20, 2008 6:31 pm
Hi
An s38 (m5) is close to a s14 so you are lookign at 2k in consumables for a full rebuild ie gaskets, timing gear, oil/water pumps and rings, the same again if you need cams, guides, followers.
Jason
StuBeeDoo
Post Wed Feb 20, 2008 6:41 pm
I know it's not quite what you were asking, but it cost me £600 to do a full top-end rebuild 2 and a half years ago using OE quality parts. So I'd say £1k minimum for a full rebuild.
e30bmlover
Ac Schnitzer prophet
Post Wed Feb 20, 2008 7:15 pm
Martinaston wrote:As they say "buy cheap, buy often".
that saying is only too true.
