- Homo Hair
Post
Tue Feb 19, 2008 11:28 pm
fuzzy wrote:but if theres very little power increase and no difference to the noise then what is the point in these?
Pretty much my thoughts..
does sound a little like the chip isnt ideally mapped for either manifold tho
march109
Post
Tue Feb 19, 2008 11:36 pm
Jhonno wrote:fuzzy wrote:but if theres very little power increase and no difference to the noise then what is the point in these?
From what I can see on the graph the chip is far more suited to the old manifold, peak figures arn't the whole story. Be interested to see what could be done if ant re writes the chip for the manifold and would be usefull to any other people out there with the same manifold seems a fe poeple over here have them now. I expect the original chip was written with the log manifold in mind since at the time that was the most common option.
I wouldn't buy one of these don't get me wrong, but with proper mapping the manifold would make a decent difference for a decent price, as someone allready said its the area under the graph that counts. It would also improve the look of the bay too.
Julian_Jules
Post
Wed Feb 20, 2008 5:59 am
THANK YOU!
Just saw the post - FINALLY someone dared to share with all of us if it was money well spent. And it looks as it was....tho marginally.
Louise should thank you for this.
Paynts
Post
Wed Feb 20, 2008 9:22 am
the other debate to have is Dyno versus Dyno I was a little disapointed in my dyno figures but then I've been told that there are considerable variations in dynos - and thta it is possible to make your dyno optimistic or pessimistic according to how you set it up
It seems that dyno power is dependant on just how you set the dyno, what gear you run the car and what load you set the dyno at and of course what type of dyno -single roller hub coupled dyno or the traditional 2 roller dyno
anyone had there car dynoed on several different set ups?
d6dph
Post
Wed Feb 20, 2008 9:40 am
I personally think a dyno read out should only ever be a guide as there are so many variables.
The best way to use a dyno in my limited opinion is to use it as a way of measuring increases not concrete proof of power. IE a run as a std car gives 160bhp, then a chipped run gives 169bhp on the same dyno you know you have a definite increase.
There is nothing to say that this figure is precisely what the car is making but it does give you a constant test, if you done the std run on one set of rollers, then the chipped run on another there could be wildly different results due to different settings.
ShepsEvo3
- Master of go faster
Post
Wed Feb 20, 2008 11:04 am
Paynts wrote:it is possible to make your dyno optimistic or pessimistic according to how you set it up
That is true of some dyno's but not ours.
www.sabre-tuning.co.uk
1an
Post
Wed Feb 20, 2008 1:30 pm
ShepsEvo3 wrote:Paynts wrote:it is possible to make your dyno optimistic or pessimistic according to how you set it up
Sheps which dyno do you use?
ShepsEvo3
Post
Wed Feb 20, 2008 1:54 pm
1an wrote:ShepsEvo3 wrote:Paynts wrote:it is possible to make your dyno optimistic or pessimistic according to how you set it up
As per graph on page 1. Dastek
No, I aint getting into any whats best dyno or results can be fudged, I certainly cannot fudge results. unless you press the brake or something on run down, but why would you?
This was a test for power and torque before and after manifold was changed. Same dyno, different results. Nothing else on the car was changed. Fair test - nothing more or nothing less.
Onz
Post
Wed Feb 20, 2008 3:33 pm
i was under the impression that a btb2 design released 18bhp on a standard engine with standard chip
Post
Wed Feb 20, 2008 5:17 pm
Onz wrote:i was under the impression that a btb2 design released 18bhp on a standard engine with standard chip
believe that and you'll believe anything, not going to happen if it did it's like re inventing the wheel
Onz
Post
Wed Feb 20, 2008 5:20 pm
yeah well.... thats what I thought until certain members of this forum repeatedly stated it
320Touring
Post
Wed Feb 20, 2008 6:50 pm
Simon- Good to see plenty of life in the old girl yet!
and to think, you were gonna part with that car
Fannymold seems to have made a difference.
just got a quick couple of questions for Paul (and no offence intended paul!not trying to tell you your job
1- Why is the correction facter different?
2- Do you not have any control over the environmental temperature?
ShepsEvo3
Post
Wed Feb 20, 2008 7:08 pm
1 - was cooler the 2nd day, 1st run was done a couple of weeks before. This makes no difference as the dyno compensates.
2 - I have as good a control over the environmental temp as anyone else. But we will have better control once our fan intake is sealed from the dyno room itself. The aim is to keep the room as cool as possible. What does seem to make a difference though is dirty air.
All the runs carried out on the car were done fairly and squarely. The best of before and after runs are shown in the graph... again to be fair (not that there was much difference between the runs)
No offence take, but unless you know how our dyno works, I knew there would be questions like this.
320Touring
Post
Wed Feb 20, 2008 7:14 pm
ShepsEvo3 wrote:1 - was cooler the 2nd day, 1st run was done a couple of weeks before. This makes no difference as the dyno compensates.
Thanks for the straight answers Paul- As you say, I'm no expert.
so thought I'd ask in a nice way.
I dont doubt the runs were done fairly!
playo
Post
Wed Feb 20, 2008 7:45 pm
A result!
Welldone Si, it's not been a fruitless excercise.
ShepsEvo3
Post
Wed Feb 20, 2008 8:24 pm
playo wrote:it's not been a fruitless excercise.
Well, those bunch of "bananas" under the bonnet look the "nuts" and she certainly sound "peachy" now.
ShepsEvo3
Post
Wed Feb 20, 2008 8:28 pm
320Touring wrote:Thanks for the straight answers Paul- As you say, I'm no expert.
Thats ok mate, I can take some stick.
If you look at the correction factors, its actually less than 100%, so the dyno has compromised for the cold air.
Dyno's like our latest Dastek and Sal's latest Dyno Dynamics are very clever at correcting for power and torque figures.
playo
Post
Wed Feb 20, 2008 8:39 pm
ShepsEvo3 wrote:playo wrote:it's not been a fruitless excercise.
Lol!! your killing me
hottuning_eu
Post
Wed Feb 20, 2008 10:14 pm
Hi,
Hopefully you´re happy with this result and dyno of the manifold !!
First f all I thank Simon for his help and testing, hopefully the air is cleared about the manifold !!!
So for the interested zone members, we have the manifolds in stock!
So looking forward doing business
Best regards,
Louise
Quaser
Post
Wed Feb 20, 2008 10:17 pm
ShepsEvo3 wrote:I've seen 227.5bhp out of a 2.7.
Who's car was that?
ShepsEvo3
Post
Wed Feb 20, 2008 10:40 pm
Quaser wrote:ShepsEvo3 wrote:I've seen 227.5bhp out of a 2.7.
Who's car was that?
Ah mate, you know very well
Post
Wed Feb 20, 2008 10:50 pm
hottuning_eu wrote:Hi,
Best regards,
Louise
Will there be any discount for Zoners?
Andyboy
- Alpina Colada
Post
Wed Feb 20, 2008 11:21 pm
18 bhp from a manifold my arse! As Simon says, bullshit baffles brains. I remember a few years ago a guy with a green C2 2.7 with the iron manifold. he came in, had the proper Alpina 6 branch fitted and it made LESS power!
Everyone moans about the standard iron manifold but in reality it's really quite good. This Hottuning manifold probably represents as good an increase in power as you're going to get - as Paul says, a bit of fine tweakery on the old ECU and it should give maybe 3-4 bhp more.
ShepsEvo3
Post
Wed Feb 20, 2008 11:25 pm
Andyboy wrote: I remember a few years ago a guy with a green C2 2.7 with the iron manifold. he came in, had the proper Alpina 6 branch fitted and it made LESS power!
This is my thoughts exactly and why we did the dyno testing.
I have seen many an exhaust system, induction kit, even uprated cams fitted and have dyno'd at less than stock power. This is why I said what I said on the other thread about actually loosing power with these types of manifolds.
Fortunately, we have see a reasonable increase. Certainly more midrange torque, and Simon says he has noticed it feels better than before low down. Obviously this must be with part throttle loads. Live mapped, I wouldn't be suprised if this car will make over 190bhp.
hottuning_eu
Post
Thu Feb 21, 2008 9:00 am
Yes for the zoners will be a discount. We´re planning a groupbuy for the zoners!
Best regards,
Louise
Justin325i
Post
Thu Feb 21, 2008 11:48 am
Louise weren't you also testing the manifold, do you have the results yet
Demlotcrew
Post
Thu Feb 21, 2008 11:57 am
ShepsEvo3 wrote:Andyboy wrote: I remember a few years ago a guy with a green C2 2.7 with the iron manifold. he came in, had the proper Alpina 6 branch fitted and it made LESS power!
Thats got to be wortht the money?
Onz
Post
Thu Feb 21, 2008 12:03 pm
dont mean to go off topic, but how did the magnex manifold look when it was dynoed on a stock motor?
ShepsEvo3
Post
Thu Feb 21, 2008 12:26 pm
sansarpur4eva wrote:Louise weren't you also testing the manifold, do you have the results yet
I think you'll find that this was the test
jack148
Post
Thu Feb 21, 2008 12:52 pm
Sorry for going a little off topic, but can you fit this manifold purely for cosmetic reasons. Do you have to have the fueling looked at or is it a straight swop? Not really interested in bhp gains n all
HairyScreech
Post
Thu Feb 21, 2008 12:54 pm
you could, i doubt it would hurt as the m20 seems fairly tollerent to the fueling being a little off, if a chip is made for it then i would say together they would be about £350 so that would be a hell of a package togeter and definatly worth doing.
march109
Post
Thu Feb 21, 2008 12:55 pm
jack148 wrote:Sorry for going a little off topic, but can you fit this manifold purely for cosmetic reasons. Do you have to have the fueling looked at or is it a straight swop? Not really interested in bhp gains n all
Yes you can, if you don't have a wild chip on your car either it would probably wouldn't over fuel like the one in the test.
jack148
Post
Thu Feb 21, 2008 1:11 pm
Thanks for that March. I have a standard set up on a 325 auto cab. Just thinking about going with full stainless exhaust plus headers for cosmetics and sound. All I need is a lottery win!!
Will keep an eye out for a group buy, if it ever gets started!!
Cheers!!
Justin325i
Post
Thu Feb 21, 2008 3:06 pm
ShepsEvo3 wrote:sansarpur4eva wrote:Louise weren't you also testing the manifold, do you have the results yet
my bad
I thought Louise was doing one seperate.
- **BANNED**
Post
Thu Feb 21, 2008 3:12 pm
sansarpur4eva wrote:ShepsEvo3 wrote:sansarpur4eva wrote:Louise weren't you also testing the manifold, do you have the results yet
my bad
Far better that we have a result from a zoner than the supplier.I hope to fit mine tomorrow,I have made up my mind on the exhaust system issue and I am going with a standard centre and rear supplied by GSF.The money 'saved' over a Longlife S/S system will help pay for a mapping session after a cylinder head swap...
