miles per gallon?
Or just disconnect the ECU...
thankyou all for your help. i went to my local halfords and they did not have any compression gauges in stock so i could not do it today. BUT i changed the power boost valve to the original bosch fuel pressure regulator and guess what? the rough idle has stopped when car is still and i can already see a difference in fuel consumption. car always ran very smooth but now even feels a bit more healthier? anyone want to buy the booster valve? LOL
delphincabby
I dont worry bout how much fuel i use as i only pay 40p a litre, the advantages of working where i do
Good for you dude
bmwe30mtech
Get that power boost valve off it!
StuBeeDoo
xx miles per £xx petrol is a very inexact science. If you haven't got an OBC to tell you what your MPG is - fill it up, drive it how you normally do for a week (or it's nearly empty, whichever comes first) then fill it up again.
Then calculate your fuel consumption.....
Miles divided by number of litres to re-fill the tank multiplied by 4.546 to give actual MPG.
delphincabby
if ur a machanic or spanner monkey, come on down were really short
