MTech2 Front Spoiler Without Foglights???
StuBeeDoo
Post Tue Feb 12, 2008 6:13 pm
OK. I'm getting an MTech2 front spoiler for the Touring and I don't have foglights.
Fitting foglights is not an option, so which of the following do you think is preferable, bearing in mind that the spoiler needs work anyway.
1) Mesh the foglight, oil cooler and air-con holes?
2) Mesh just the foglight holes?
3) Smooth-over the foglight holes and slightly re-shape/enlarge the brake ducts?
Personally, I prefer the third option although it's going to be more work. What do you lot think?
aceraf
Post Tue Feb 12, 2008 6:17 pm
Hate mesh on e30's. Do a photoshop to show what you mean about opion 3. easiest thing would be just to fit fogs, and not wire them in. problem solved. :D
Breaking 325i Touring
StuBeeDoo
Post Tue Feb 12, 2008 6:32 pm
I don't have photoshop and if I did probably wouldn't be capable of using it.
What I'm thinking is something similar to these, only maybe not quite so big.
(My apologies to Spadge for nicking his photo')
I don't particularly want to go the mesh route as I think it's "council". Am I right??
Chris-W
Post Tue Feb 12, 2008 6:35 pm
StuBeeDoo wrote:I don't particularly want to go the mesh route as I think it's "council". Am I right??[/color]
Yes! :D
George_Of_The_Jungle
Post Tue Feb 12, 2008 6:37 pm
gimp is a free version of photoshop, available on the internet
http://www.gimp.org/
StuBeeDoo
Post Tue Feb 12, 2008 6:39 pm
Chris-W wrote:Yes! :D
Thought so! 8O
StuBeeDoo
Post Wed Feb 13, 2008 8:11 pm
Any more comments? The more the merrier - good or bad! :D
toby
Post Fri Feb 15, 2008 8:45 am
Yes option 3 sounds good and more cooling air to the brakes potentially. I don't imagine you'd have to do much. I'm sure I've seen examples of this option somewhere.
leedg
Post Fri Feb 15, 2008 10:23 am
leave them empty....
toby
Post Fri Feb 15, 2008 1:04 pm
The scoop bit that normally goes in next to the fog light shown here,
can you not use those instead of fog lights?
Turn them around and use nearside one for offside and vice versa, adapt to fit.
Alyman
Post Fri Feb 15, 2008 1:12 pm
Get your hands on a cheap set of fogs then build up a few decent layers of of primer on the lenses. Sand them flat, then spray them body colour and install.
Ain't nothin fills a foglight gap like a foglight :D
320Touring
Post Fri Feb 15, 2008 1:22 pm
Alyman wrote:Get your hands on a cheap set of fogs then build up a few decent layers of of primer on the lenses. Sand them flat, then spray them body colour and install.
lol! Aly to the rescue yet again!
Stuart- I'd fit fogs mate, even if not wired.
your car is too nice for any "schlaaag look" tactics...
Ziggy
Post Fri Feb 15, 2008 1:47 pm
If they don't fit as standard, I'd still expect some foglight blanks (from a standard facelift valence) could be made to work?
suzie650
Post Fri Feb 15, 2008 5:34 pm
Meshing is council, but not that council...
Imagine this extended to the fogs, and a nice custom air duct behind it to at least use the drag created by the big hole
Not too bad, is it?
StuBeeDoo
Post Fri Feb 15, 2008 6:26 pm
toby wrote:The scoop bit that normally goes in next to the fog light can you not use those instead of fog lights?
That's pretty much what I was thinking.
I used to have a photo' somewhere of a German E30 Touring with the foglight holes meshed - that was what made me think of it. I'll have to see if I can find it.
Neil, when I had foglights, I got through 2 and a half pairs in 18 months. I may have been unlucky, but I've been put off by that experience. :roll:
suzie650
Post Fri Feb 15, 2008 6:35 pm
If you're looking for photos, e30.de, under "fotostories"... Only good stuff in there. And hardly any m20b20/25. it's at least 2.7, or s50/s38. Great suff!
As for your problem, you could also try to make covers out of fibreglass yourself? That is if you don't want to mesh them.
StuBeeDoo
Post Fri Feb 15, 2008 6:57 pm
suzie650 wrote:As for your problem, you could also try to make covers out of fibreglass yourself? That is if you don't want to mesh them.
That's another thing I've been thinking. Fibreglass + modded standard scoops = bigger scoops and no foglight holes.
I think the photo' I'm thinking of did come from e30.de.
euan
Post Sat Feb 16, 2008 9:36 pm
i think the idea of just painting over fog lights is genious !!!!!!!!!!
