gaz fully adjustable front and rear coilover[new buy 07/05/]
Enter a group buy or look here for zone discounts
mikekean
Post Fri Feb 08, 2008 7:13 pm
why have you got some lying around? how much you looking for em?
Trise30rally
Post Sat Feb 09, 2008 1:20 am
I had some on that old 316 of mine are they the same size? otherwise a mate of mine has broken a few 325's so he will definately have some spare....
BadDave
Post Sat Feb 09, 2008 1:33 am
mikekean wrote:so wats the turn around on sending them your struts and you getting the finished product made. i share a workshop with my brother and my working area is infron of the door so the car cant be laid up for more than a 2 weeks really as he is also building a rally car and needs to be able to get it in and out the shed.
When I sent mine back for rebuilding,it only took a couple of days
Will obviously take a little longer to add the threads and adjusters to the strut bodies
I was well impressed with there customer attitude and turnaround time
HTH
Dave
elf
Post Sat Feb 09, 2008 7:53 am
probably no more than week turnaround.
but they do need front strutts before.
Nick_TBMW
Post Sat Feb 09, 2008 3:56 pm
benjy wrote:
UweM3 wrote: Fit a Z3 plate and all will be fine.
And on this point you are absolutly certain??? Do you have a pic of these Z3 plates?
I'm still uncertain, this is a lot of money to shell out in one hit, not that i'm slagging! It looks the mutts nutts 8)
Do GAZ require a pair of struts first or is there a surcharge?
Cheers,
I've got the Gaz coilovers and the only strengthening mine has on the rear towers is a strut brace (whch is effectively Z3 plates with a bar between them).
No problems so far and I've done 2 trackdays and about 2500 miles (some of those are on very poorely surfaced antqiue Roman roads).
oze30
Post Sat Feb 09, 2008 5:56 pm
Bugger!! If only I could get the struts off for that long!!! :(
agreen
Post Sat Feb 09, 2008 6:11 pm
elf i sent you a pm did you get it ?
agreen
Post Sat Feb 09, 2008 6:38 pm
ahh balls to it ill have a set - if there is a
reasonable deadline for sending the old struts off ?
are the top mounts you offer the adjustable ones
i will need to do some reserch into the spring rates i need so will need to wait till that is sorted but i think it should not take to long
can you give me a buz on 07866845511 please thanks
Karan
Post Sun Feb 10, 2008 7:03 pm
i also want a set of these but will be calling to discuss spring rates for my car (heavy engine), and also are the front top mounts camber/toe adjustable?
also for reference, have you got a contact there who i can talk to and what is ure name again mate so i can quote you please
how many peeps so far? need these asap, car handles like a pissed pig at the moment
agreen
Post Sun Feb 10, 2008 7:35 pm
i am looking for a contact number to finalise details also need to speak to a person before spending £700+ as you can appreciate mate
Karan
Post Sun Feb 10, 2008 7:48 pm
oh and these are the GGA top of the range ones yes?
Karan
Post Sun Feb 10, 2008 7:49 pm
and will they rub on rear tyres or rear strut housings?
Beemer Redeemer
Post Sun Feb 10, 2008 8:31 pm
I'm registering my interest on these.
I have just disassembled my front struts ready for sending to Gaz anyway so a group buy seems like the sensible thing to do.
Might be wrong here (so please correct me if so), but i think you need to send the 51mm struts to be used rather than the 45mm struts.
I am building my E30 to enter in the PBMW cup (starting end of March). I just need to check if we can run coilover rear suspension as most of the competitors cars ive seen have been the shocker and separate spring affair.
As agreen has said, i will just need to look into spring rates. But i'm provisionally in.
Can we definitely confirm they are coilover rears ? Cheers.
1. Trise30rally- race/rally setup
2. mike - rally setup
3. agreen (provisional)
4. Karan (provisional)
5. Beemer Redeemer (provisional) Race setup
6.
7.
8.
Cheers :D
James
agreen
Post Sun Feb 10, 2008 8:37 pm
6.
7.
8.
what he said prov !!!
but need to speak about spring rate options i have been advised of what to go for and will take his advice and want to see if you can do them and
also need to check top mount specs , and clearence issues
Need contact number !!!
Trise30rally
Post Mon Feb 11, 2008 1:00 pm
Ok we have 5 now lets go :D
agreen
Post Mon Feb 11, 2008 6:04 pm
Posted: Mon Feb 11, 2008 11:00 pm Post subject: Re:
no three are porvisional we (i ) need more info before we go rushing into it as state baove they say provisional next to them !
i have had no contact yet from the guy rganising this but i am iin no rush to rush in i want to check they have the correct spring rates etc as i am sure the other do to
so wee need a number >?
Karan
Post Mon Feb 11, 2008 6:36 pm
yes i need to confirm rates and any rear turret/wheel issues
also need to know the nature of the front top mounts and if they are camber adjustable
can someone please shed light on this as i would like these sooner rather than later
Dave_M3
Post Mon Feb 11, 2008 6:42 pm
They're sexy!!!
Shame I'm not ready for these. What's the normal price on them. Would be perfect for the track car, might get some during the summer.
gareth
Post Mon Feb 11, 2008 10:35 pm
i'm not after any as i have ledas already but a point to check with GAZ...
Do they clear the fuel breather pipes etc that run through the offside rear arch? the ledas don't so at present, i've still got my old pigtail springs on and have removed the springs from the rear coilover bodies. i think the pipes will need re-routing inside the car or something...
elf
Post Thu Feb 14, 2008 8:24 am
gareth wrote:i'm not after any as i have ledas already but a point to check with GAZ...
hi mate sorry not been on been buisy.it would be best if you phone gaz direct as dave was originally half owner leda until he brought out.
for personal reasons i wont discuss.
as for the rest all i said is i need five to go ahead.
if you all pm me your details then i pass them onto dave.
he will contact you all and awnser all questions on spring rates etc.
you are still not abliged to buy until your happy with what your getting after that.i only needed five to get ball rolling not to hand over any money until you all been contacted by gaz shocks direct.are we clear now. :D
oze30
Post Thu Feb 14, 2008 8:29 am
I'll go for it.. as long as we can work out some spring rates for the ass end of a touring with a 55l LPG donut and an M60 in the front!!
agreen
Post Thu Feb 14, 2008 5:45 pm
you have a pm with my details as you requested mate thanks
Karan
Post Thu Feb 14, 2008 6:48 pm
oze30 wrote:I'll go for it.. as long as we can work out some spring rates for the ass end of a touring with a 55l LPG donut and an M60 in the front!!
hello dude
prob go for same as mine: 600 front 300/350 rear
should be a good starting point and if necessary you can change from there. Those rates are track biased, even though mines a daily.
MJG
Post Thu Feb 14, 2008 6:53 pm
MOFO! That is perfection. Don't have the money yet though - poo! I was unaware of true rear coilovers being available. I will save my pennies for a set, hopefully the group buy will still be on! Brilliant.
Karan
Post Thu Feb 14, 2008 6:55 pm
MJG wrote:MOFO! That is perfection. Don't have the money yet though - poo! I was unaware of true rear coilovers being available. I will save my pennies for a set, hopefully the group buy will still be on! Brilliant.
hopefully there will now be some sweet handling e30s in the world after this! :mad:
MJG
Post Thu Feb 14, 2008 7:00 pm
Yeah haha, this is really good, even if I miss this group buy I can hold out til another one hopefully comes around, or I'd happily promote Gaz in the British Drift Championship this year for the same trade price in a few months.
agreen
Post Thu Feb 14, 2008 7:16 pm
do you just need to send the shock housing off to gaz when this all goes ahead ?
or do you need the inserts ? thanks
agreen
Post Thu Feb 14, 2008 7:19 pm
Eww also i have rouge engernering rear top mounts will these be able to be used ?/ sent off ? thanks
Karan
Post Thu Feb 14, 2008 7:21 pm
u can send empty struts
as for the rear top mounts, the gaz coilovers have rose jointed top moounts already on them so u wont need ure rogue ones-sell them
agreen
Post Thu Feb 14, 2008 7:46 pm
ohh right cool ill list them up for sale then ! thanks i just deffo wanted to know i did not need them
so do i need to buy some e36 cab ones to send away ? with the struts cheers karan
gareth
Post Thu Feb 14, 2008 8:28 pm
i'm not going to call him, i'm not looking to buy any! just thought it should be checked / considered by anyone looking to buy a set as it'll add a load of work to fitting them.
ppcsam
Post Sat Feb 16, 2008 10:33 pm
If this GB is still on then I am definitely interested. However I have run LEDA coilovers in the past on my E30 race car and the rears did catch in the arches. I want to be sure that this won't happen with the Gaz GGA units as they are going on a road/trackday car this time and I want to keep it a little more civilised.
Elf - I'll send you a PM with my details and would really appreciate a call from someone at Gaz to confirm spring rates and potential clearance issues etc. If that all checks out OK then I'm in and I'll get the IS on stands.
6. ppcsam - (track day spec)
7.
8.
elf
Post Sun Feb 17, 2008 4:45 pm
just need mikes details
and trise30rally details then i can give them to dave to
contact you all direct for specific needs etc.
and any other questions you have.
i have pm them both so if anyone can give them a nudge
as some people want these sooner than later
regards gaz.
agreen
Post Sun Feb 17, 2008 5:17 pm
3. agreen (provisional - Track day spec)
7.
8.
thanks for every thing elf,
i know this seems like alot of hard work as your are getting nothing out of it but we are all trully greatfull i am sure , cheers elf
elf
Post Mon Feb 18, 2008 7:40 pm
agreen wrote:1. Trise30rally- race/rally setup
7.
8.
ok mate glad you appreciate it.
still waiting for
mikes and trise30rally
anybody know them to contact them as some want asap.
i have pm them both
