Feeler on GB for Polycarbonate Window Kit
Enter a group buy or look here for zone discounts
RobCallow
Thu Dec 01, 2011 6:33 pm
I Have been in contact with a supplier of poly window kits just trying to gauge interest in a GB.
The more interest the lower the cost.
1. RobCallow
325i Track Project.
rix313
Fri Dec 02, 2011 3:07 pm
A current cost and estimated group buy cost would be handy? Also a manufacturer and how many windows?
RobCallow
Fri Dec 02, 2011 3:35 pm
http://www.plastics4performance.com/
Current price can be found on here discount will depend on numbers so just trying to gauge interest at the minute to see if it is worth while arranging a GB
Cheers Rob
325i Track Project.
RobCallow
Fri Dec 02, 2011 3:42 pm
Cheers Rob
325i Track Project.
215m3
Fri Dec 02, 2011 11:02 pm
Hi Rob
I'd be up for this, side windows and possibly rear foe E30 M3.
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
rix313
Sat Dec 03, 2011 11:27 am
I'm interested depending on the price. Have you spoken to them yet? Most companies will have some sort of volume based discount structure for this kind of thing already worked out.
Reeeedish
Sun Dec 04, 2011 10:42 am
Hi Rob,
If you don't get much luck with P4P,
try www.acwmotorsportplastics.co.uk
Ask for Tony. I've been dealing with him for a good few years now and we've become good friends.
Be sure to mention me and he'll help you out as best as he can.
ACW's polycarb/lexan windows arn't heat formed like P4P's (i.e they're flat), but that tends to be reflected in the price.
If you're after a very OEM look by using heat formed sheets (which can be bonded in) to take up the multi axis curves of the rear screen, then I would suggest P4P.
However, if it's a track/race car and you're happy with bolting them in then try ACW.
Here's some of ACW's windows on a couple of E36's I built:
You can see they are flat sheets, and are supplied with M5 cap heads & nylocs plus aluminium rivets.
And some closer pics:
Hope that helps,
James :D
Hoobs
Mon Dec 05, 2011 11:11 am
I'd be up for a set for my track car.
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
Pyros
Mon Dec 05, 2011 11:42 pm
would these be road legal?
peterrigby123
Sat Jan 07, 2012 11:12 pm
not sure if this thread is still going but im definitely interested. Just put a couple of plastic windows in a bmw compact rally car and couldnt believe the weight in the original glass!
mccarthy
Sat Jan 28, 2012 2:00 am
I'd be up for group buy with acw. Its around what I'd like to spend. Do u know if the rear comes with rubber seals or have to be bonded in?
Hoobs
Sat Jan 28, 2012 6:25 am
Pyros wrote:would these be road legal?
Yes, my car went thru test the other day.
@mccarthy - just use your old rubbers.
Fitting poly windows made a big difference to how my car feels. Definitely well worth the effort imo.
2002
Rallyprep_UK
formerly Driftnething
Mon Feb 06, 2012 9:21 am
I would be interested in a set. Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Mon Feb 06, 2012 2:20 pm
Need some prices! I would be more interested in the scratch resistant windows TBH but £340+ is 8 legs of venison IMO :)
Rallyprep_UK
Mon Feb 06, 2012 4:04 pm
DanThe wrote:Need some prices! I would be more interested in the scratch resistant windows TBH but £340+ is 8 legs of venison IMO :)
x2 :wink:
RobCallow
Sun Feb 12, 2012 11:11 pm
I forgot about this thread!!
I will contact all the companies and see what offers we get.
325i Track Project.
nickso
Sat Feb 18, 2012 12:09 am
I'm interested also. :)
'88 e30 328i M52 track bint.
Hoobs
Tue Feb 21, 2012 4:20 pm
Weighed my car today. 1040kgs exactly with fuel.
2002
miketemplar
Sat Mar 17, 2012 12:57 pm
Hi, As a new member, recommended to here by a customer. Just like to say I manufacture polycarb windows and supply heated windscreens too, for most BMW's, as a clubman competitor and a windscreen fitter for over 30 years my advice comes free and my kits are'nt dear. Check them out on ebay. In the meantime, I'm looking forward to installing my S.14, and tips are most welcome! Cheers!!
rix313
Sun Mar 18, 2012 1:36 pm
Hi Mike,
Good to see you've signed up :) What sort of group prices to you recon you could offer?
What do heated screens cost?
miketemplar
Sun Mar 18, 2012 4:03 pm
Hi, I've got screens for nearly all BMW's, including the E.30, prices start at £225. As for the polycarb, well you will see I already sell at trade prices, but would be content to offer another 15% if 4 or 5 of you can stitch an order together. I can also mould (thermoform) the rear quarters on the E.30 so that they can be mounted on the original fittings, if required. Thanks for the reply.
Sun Mar 18, 2012 5:27 pm
Mike can you form the fronts so they can be used with the standard winders? And would they be pretty scratch resistant?
miketemplar
Sun Mar 18, 2012 8:00 pm
Any window can be formed, I'm currently doing some opening rear quarters for a guy with a Mk2 Escort, and they have to be formed to be able to open correctly. The same holds true with your front windows, in order for them to operate properly on the original winders they need the curve putting in them, Makrolon AB hard coat polycarb will cost a fair bit more (£180), but last much longer.
Sun Mar 18, 2012 8:32 pm
Thats what id be interested in, no point fitting stuff that gets scratched up in no time.
Can you give an estimated price for formed fronts and fixed rear 1/4's and rear screen
miketemplar
Sun Mar 18, 2012 9:06 pm
Formed front and formed fixed rears? Flat rear screen, all in h/coat is £360 inclusive. H/coat only comes in clear.
