Eggenbeefburger Grp2 e21 BMW 320
Brian28
Post Fri Jul 06, 2012 11:33 am
rix313 wrote:
Would have to find the car in the garage first :D
You're not wrong :D quieter week coming up so it should all be looking a bit different in there by next weekend
Hoobs
Post Mon Jul 09, 2012 10:10 pm
Nice pic from last weeks sprint at Clay Pigeon.
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
Demlotcrew
Post Mon Jul 09, 2012 10:57 pm
Good ride height Mark! :)
Hoobs
Post Tue Jul 10, 2012 7:32 am
Down to some good advice. :)
2002
Demlotcrew
Post Tue Jul 10, 2012 8:40 am
The sport evolution spoiler at the back looks like its holding on for it's life. The down force/drag is clearly tiltting it back and causing the front edges to raise up and bend the boot panel.
Is it a full width spoiler? Ie will it bolt on to an M3?
Hoobs
Post Tue Jul 10, 2012 10:00 am
Yes, it's full width but I'll go check for flex in a while. It could be just the angle of the photo though, as I was only in 2nd gear and not going particularly fast at this point.
Last time I was out before Clay Pigeon. I can't see any flex here but will certainly investigate and look to see if additional bracing is called for?
2002
MillRat
Post Tue Jul 10, 2012 7:04 pm
I like the paint scheme of your car. It is striking without being obnoxious. It looks to be a very tidy car, congratulations.
Cheers,
Michael.
mattrs
Post Tue Jul 10, 2012 7:11 pm
MillRat, that car looks :cool: Is it yours?
Do you know what splitter that is or where it came from?
Demlotcrew
Post Tue Jul 10, 2012 10:26 pm
Hoobs wrote:Yes, it's full width but I'll go check for flex in a while. It could be just the angle of the photo though, as I was only in 2nd gear and not going particularly fast at this point.
But Mark, you don't have the gurney extended as far out, I did a quick over exposure and you can see the leading corners lift, but not as much as the previous photo.
Andrew
Hoobs
Post Tue Jul 10, 2012 11:46 pm
Doh! :o:
Had a look today and there is some flex so we've decided to fix some tabs to underside of boot lid that will stop it. Another solution might be a twist fastener that will do the same job and not interfere with removal of the boot lid. It's a relatively easy fix either way.
Thanks for positive comment Millrat. Has to be said, your car also looks very nice.
2002
MillRat
Post Wed Jul 11, 2012 1:37 pm
mattrs wrote:MillRat, that car looks :cool: Is it yours?
Thanks, and yes it is mine.
The splitter is a series 1 Alpina (without the brake ducting ports).
I bought it in Australia from a business who deals in Alpina parts.
No worries, I always like reading about gradual (and ultimately successful) project builds. Race car projects even more again.
Cheers,
Michael.
Hoobs
Post Sun Jul 15, 2012 10:56 am
Finally replaced pads front & rear and took time to bed them in properly. I have to say I am mightily impressed with the Hawk pads. I'm not sure of the brand they replaced, as they came with the calipers, but the Hawk are far better. The pedal feels great and there's no squeal when hot, which was a problem I had with EBC reds. I've been looking at ducting to try and improve cooling.
On a side note, is anyone doing Retro Car Mag event at Brands in 3 weeks?
2002
Hoobs
Post Sun Jul 15, 2012 4:31 pm
Pics from Performance BMW Magazine track evening at Brands Hatch last month.
2002
Demlotcrew
Post Wed Mar 20, 2013 4:25 pm
Topic moved in here :)
Hoobs
Post Mon Oct 21, 2013 5:46 pm
It's been a while since have posted here but have still been tinkering with old German metal. Seeing as I have a thing for E21 and a desire to enter the Cornwall Speed Championship, I figured I would build a race car from scratch. Previous cars have been built by other people and come to me as already built track cars. This time I started with a bog standard, hearing aid beige 316.
As I also had a Group 2 arch kit and fiberglass boot and bonnet tucked away, I figured it made sense to use them.
As with any serious track car, all the usual sound deadening and trim etc, was removed. The original inspiration was the old Eggenberger Group 2 car but I figured I needed a more extensive cage. I also took out the original seat mount, so that I can get myself as low as I can. Fortunately, being a non-sunroof car, there was very little rust. I did get a message to let me know how sad the previous owners were, to see the car they'd cherished ruined! Obviously I don't agree and think there are enough standard 316's out there, not to worry about one less road car.
After we painted the boot, we mounted a fuel cell and swirl pot. It's only a 12L tank (with a 2L swirl) but I'm keeping weight to a minimum and sprints and hillclimb aren't too long generally.
We took out the boot floor and rear firewall to save weight and replaced with aluminium. After that, it was paint inside, screen and poly windows.
Front screen is in. Poly sides and rear are next. :)
Engelmann mirrors are just about the only aftermarket ones that suit an e21.
The only problem has been the crappy arches from Pesch. They are absolutely useless, but fortunately I have a UK supplier now and they're first class. :)
So, I'm now at the point where I need to look at engine choice. I'm limiting power to around 200bhp, so that I can leave the OE e21 LSD & driveshafts for now. Suspension is from Gaz and brakes are Wilwood.
I'm thinking supercharged m42? winkeye
2002
rix313
Post Mon Oct 21, 2013 9:04 pm
Mega 8)
LondonTom
Post Tue Oct 22, 2013 12:39 am
Nice - do you also race in the compact cup? A pal of mine competes in the championship?
Hoobs
Post Tue Oct 22, 2013 5:41 am
Well spotted but no, the guy who did my cage also did a lot of Compact race cars.
2002
Hoobs
Post Wed Oct 23, 2013 12:41 pm
Spent the past couple of days going through the regs and am staying with m10 power as a result. Hopefully I can source a big valve head and lumpy cam to suit? I already have a set of 40's to use.
2002
Post Wed Oct 23, 2013 1:17 pm
Hoobs wrote:Spent the past couple of days going through the regs and am staying with m10 power as a result.
Will be expensive but :cool:
Looks like it will be a v nice car once finished :D
Hoobs
Post Wed Oct 23, 2013 3:53 pm
DanThe wrote:Will be expensive but :cool:
I don't think I'll be going too wild for the first season, but if anyone knows someone with a BV head and cam, please give me the nod.
2002
Hoobs
Post Mon Oct 28, 2013 9:48 pm
A bit more progress and apart from some minor bits of trim and a drivers door lock, the body is nearly done.
I think the Minilites look pretty cool, but Stanced UK Ltd have offered some deep dish crosspokes, that will look period correct.
The battery arrived today and only weighs a couple of Kg's.
2002
Hoobs
Post Thu Oct 31, 2013 5:18 pm
I need to start putting a list of ''to do'' jobs together though, as I'd really like to get it finished for the Performance BMW Magazine track day at Brands Hatch on February 24th next year.
The engine I have is an e30 318i m10 and they have bigger valves as standard. I plan on using a rally profile cam from Cat Camshafts, as I figure I need more torque over outright power. I want to do some gas flowing and match the inlet ports to the manifolds, before fitting the Weber carbs. I also want the longest velocity stacks I can source, but as they're stupidly expensive, I am wondering if I could use lengths of silicon hose to extend the ones I have? I know it won't make huge power but it'll still be fun in such a light shell.
Apart from the engine, I also need to install the pedal box and sort the brakes. There are Wilwood calipers but I'm tempted to ditch the servo and mod the pedal, to get more leverage. Anyway, a few more pics.
2002
DawieM3
Post Wed Nov 06, 2013 7:29 pm
Mark,
Drop a S14 in it. Youve been in one that goes, :D :D :D so why settle for less.
Cheers,
Dave
E30 M3 Track car S14, 2.5l
2002, 2.0l fuel injected
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
2002 E10 -M57 on e46 floorpan
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
goosiegander
Zonegoose
Post Wed Nov 06, 2013 7:30 pm
Porn! :D
Hoobs
Post Wed Nov 06, 2013 8:25 pm
I would if I could afford it Dave, although I know someone with a 2 litre s14 in need of building up.
What I am doing though, is initially going to run the standard injected 1.8, but with a pair of Webers and 4 branch exhaust manifold. I also have a lightened flywheel, seeing as a new clutch will be going in anyway. The reason for this, is that we just want to get the car finished. Once it's actually driving we can start sorting the suspension geo' etc and iron out any problems. Whilst that's going on, we can start building a hot 2.0 litre m10 to eventually replace the 1.8.
The idea of having that S14 on a pair of 45's is quite an exciting one though!
Hopefully the tyres will be here tomorrow and I can get the new wheels bolted on.
2002
Hoobs
Post Thu Nov 07, 2013 10:21 pm
Changed wheels & tyres today.
2002
Post Thu Nov 07, 2013 10:38 pm
Looking very racy. 8)
Hoobs
Post Sat Nov 23, 2013 10:19 am
A combination of being shafted for solicitors fees and a move to Cornwall have meant the E21 track car has gone to pastures new. Sad to see it go, but it'll be in good company with a brace of 2002tii race cars.
Also means I have been able secure an e30 M3 keeper, so not all bad news.
2002
appletree
Post Sat Nov 23, 2013 10:46 am
How have I missed this thread!
NoTurbo
Post Sun Nov 24, 2013 8:40 am
Wow that is amazing!
When do you plan to have it running?
Hoobs
Post Sun Nov 24, 2013 8:55 am
Hoobs wrote:A combination of being shafted for solicitors fees and a move to Cornwall have meant the E21 track car has gone to pastures new. Sad to see it go, but it'll be in good company with a brace of 2002tii race cars.
2002
Post Sun Nov 24, 2013 11:31 am
The only good E21 is a sold one ! :D
Hoobs
Post Sun Nov 24, 2013 11:33 am
You knows it Pete. ;)
Once picked up the M3 I'll drop by.
2002
MarkT
Post Mon Jan 13, 2014 10:21 pm
Love the e21 build, tidy workmanship
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
