Hiya
Ive decided to go down the m20b28 route for my e30 turbo project. Aim is around 450bhp
At the moment, i have a m20b25 engine, m52b28 crank from a z3, and m20b20 engine in the car at the moment.
What compression ratio should i expect from the m52b28 crank, with b20 rods, and b25 pistons? (which mls headgasket do i need) - i dont intend to deck the block.
I intend to get the m20b25 head welded up, use an ebay manifold and hx35 - which BOV is recomended, and also can anyone recommend a company to do the head welding?
Im near heathrow if that helps.
Q
building a m20b28 turbo - advice pls
Quaser
gromgsxr
http://e28-535i.com/upload/M20_CR_Calcs.xls may help some.
dont forget to take into account that the piston will sit 0.5mm aprox lower down the cylinder bore.
Quaser
thanks for the linkgromgsxr wrote:http://e28-535i.com/upload/M20_CR_Calcs.xls may help some.
just making sure im using it right, i take it that i need to be looking at the 2nd row (8.8:1 standard)
then changing the head gasket thickness to 0.07, and adding 0.02(inches) to make up for the 0.5mm block difference, i get a Cr ratio of 8.37
Is that an ideal CR for boosting, or should i go lower to 7.55 without and machining of the block!
Mind you, these values will raise a bit as there is no compensation for the head skim. Will i need a vernier pulley?
Pinchy_Larou
Useful excelgromgsxr wrote:http://e28-535i.com/upload/M20_CR_Calcs.xls may help some.
gromgsxr
dont forget to change the engine cc size as well up to 2793cc as will change the compression as well
Quaser
where do i do that?gromgsxr wrote:dont forget to change the engine cc size as well up to 2793cc as will change the compression as well
edit - i didnt realise you can change that value - makes more sense now.
thanks
reggid
9.3:1 without being decked 0.5 mm this is nominal and fine for a turbo engine
E30 325is with M20B31
Quaser
I worked it out to be 8:1 with 0.14 gasket
