ebay turbo kit
Nobby_N
No they gain you a shed load of respect here on the zone, pm pacerpete as he loves this sort of modding matey
leecjones
???? lol....not sure who he is.... and I was honestly not trying to get ripped to pieces so I have my fingers and toes crossed that I don't
Nobby_N
Most of us wierdos on here like the standard look and the fact bmw got it right in first place! Loads of people turboing e30s so crack on mate!
leecjones
cool... well im still very much at the drawing board so until im sure whats right the e30 cab will stay standard
ross_jsy
Waste of time and money. The turbo will be cheap chinese scrap that will destroy itself in no time. The manifold will crack and need constant repair/bracing and I pretty much guarantee the prebent pipes won't be correct so you will have to spend extra ordering new ones. The rest of it will all be cheap and no doubt fail early.
Stay away from generic ebay turbo kits, complete waste of time.
Have a read through this if you are serious. Sums up the ebay kits near the top:
http://www.e30tech.com/forum/showthread ... 43&t=74816
Wouldn't bother turboing a cab, power delivery doesn't suit the cruising nature and they are floppy turds as it is. Wouldn't mind an m30 in a cab though, lazy torquey power perfect for wafting around
leecjones
thanks for the summary .... looks like ive bought the wrong car.
never mind
never mind
b12rlw
Similar kit to how mine started out. Manifold is o.k. cooler is all well. My turbo blows at low revs and managed 25psi repeatedly and still works (p!ng p0ng knock off or not does whats needed). tubing is all standad, I was lucky I have an ac tig at hand. Dunno what the pic is all about though, shows an internally gated turbo and an external gate??? Get injectors and ecu and learn turbocharging with cheap parts, before spunking loads of dosh on expensive stuff!!!
b12rlw
ross2009
Nobby_N wrote:No they gain you a shed load of respect here on the zone, pm pacerpete as he loves this sort of modding matey
Gunni
Nothing wrong with those manifolds, good for 450+ and don´t crack from what I have seen.
ross2009
tbh I had an eBay manifold running 400 bhp mine never cracked
Quaser
im selling a turbo/manifold kit with injectors & decompression plate on ebay at the moment
tomislav
Turboing e30's CAN be a riot, friend of mine did it to his 325 and it was quite amusingly fast.
If you plan to go past about 290bhp then uprated everything is a must.
Beware tho, you will probably need deep pockets to do it properly.
ross2009
deep pockets ain't the word depend to what level you do it tootomislav wrote:Turboing e30's CAN be a riot, friend of mine did it to his 325 and it was quite amusingly fast.
I had 6 k just in my engine
mine was pushing over the 400bhp mark tho
leecjones
Thanks for the comments.... Quaser.... I believe I have bought your kit
leecjones
where can I get a downpipe from??
ross2009
you cant you have to make it your self or get an exhaust center to make you oneleecjones wrote:where can I get a downpipe from??
the only problem with turboing a car thats not as standard is that you cant really go and just buy bits of the shelf some of it is custom work everybodys set up is different so sombody downpipe for example wont or might not fit another with out modifying it again more custom work to make it fit
leecjones
ok, no worries, I know a couple of lads that own a garage so will ask if they know someone to get it done
leecjones
started the turbo conversion... some small issues to deal with..
one is the water bottle for the screen wash doesn't fit in the car next to the turbo.?
has anyone had the same issue
ross2009
yeah bin it lol
I just bought a little universal one
stunt-nut
leecjones
Hi Stunt-Nut.. its not an ebay kit, I have found most parts separately on ebay though..you thinking of doing a turbo
leecjones
final completed the turbo and had it dyno'd and rolling road at 290 bhp
need to find a set of better spark plugs with smaller gaps to get more as the car wasn't getting full range
TarmacAdam
Just read this good to hear how it's got on should go ok at that
leecjones
its good - really strong at pulling through the power and the graph is mint..
leecjones
not to every ones taste... but I just love it....
