cam sync
gromgsxr
Post Tue Nov 20, 2012 10:39 pm
is there any off the shelf options for a cam sync for m20 as am looking to go sequential injection with coil on plug?
Gunni
Post Thu Nov 22, 2012 9:22 pm
I think there is something available from Pure Performance Factory in Sweden.
However a simple 10mm flat ally plate can be cut/machined easy to replace the ignition cap, then drill and fit a hall effect or VR sensor and wire to the ecu.
Where the rotor used to bolt on there are threads, you can simply screw in a bolt there that will swing past the sensor within 1mm distance and thus get your trigger point.
Gunni
@ 2012 VEMS group buy !!
Nobby_N
Post Thu Nov 22, 2012 9:25 pm
Hey Gunni theres a pose out looking for you on this thread! keep ya nut down lol
http://www.e30zone.net/modules.php?name ... &start=250
gromgsxr
Post Thu Nov 22, 2012 10:41 pm
yeah iv seen that option about with the alu but not to sure what i can knock up with just a trusty hacksaw and a file,
