Best engine to turbo? completed & the results are in :)
Cook318IS
Post Thu Jul 26, 2012 11:35 pm
Can it do wheelspins? :P (very very jealous though!)
craigieeb
Post Thu Jul 26, 2012 11:37 pm
I'll probably put a new vid up over the weekend after iv done the little jobs
and burned the old rear tyres off............. in the back lane
Barx325i
Post Thu Jul 26, 2012 11:48 pm
Cook318IS wrote:Can it do wheelspins? :P (very very jealous though!)
can you do any sweet jumps? :)
Gunni
Post Fri Jul 27, 2012 5:11 pm
This will be fun to see mapped.
Gunni
@ 2012 VEMS group buy !!
craigieeb
Post Fri Jul 27, 2012 6:37 pm
Cant wait for that day, hopefully it will v/soon :cool:
need to work out why its pumping way too much fuel through,
and also why the idle keeps rising, when the vacuum line is connected to the ECU,
If I take it off the ECU the idle comes right down..
Gunni if I send you my recent log file can you have a quick look over it and see if anything is wrong somewhere?
Gunni
Post Fri Jul 27, 2012 10:04 pm
the vacuum line NEEDS to be connected to the ecu.
The fuel just needs tuning.
Don´t worry about the idle, I´ll sort that when I see the car.
Keep sending me logs.
Gunni
craigieeb
Post Fri Jul 27, 2012 10:23 pm
I'll keep it connected dude,
when i say the idle is high im talking 2600rpm
Im going to pull the inlet etc off tomorrow just incase there are any air leaks or anything untoward,
I'll send you a log over...
Gunni
Post Fri Jul 27, 2012 10:43 pm
Don´t pull it off unless I tell you too.
This is where we do things pro style and not just random messing around like.
Log will tell me what needs to be done if anything.
Almost certainly its so rich without the vacuum line the power goes down and idle looks good, but the case maybe that slight adjustments in the ecu are needed and this problem goes away with the 2600rpm idle.
no big deal, the more you log the better and quicker problems get resolved.
Gunni
craigieeb
Post Fri Jul 27, 2012 11:02 pm
Ok i'll hang fire and see if there is anything that can be adjusted on the ecu dude
craigieeb
Post Sun Jul 29, 2012 3:27 pm
All the little jobs have now been done and there's nothing more to do except DRIVE IT :twisted:
BUT.....
it's undrivable to be honest :( :(
The idle just keeps rising and rising,
it was sat at nearly 3000rpm, before I had to switch it off, didnt like that 1 bit.
seems the warmer the engine gets, the more it sits higher :?
Gunni
Post Sun Jul 29, 2012 7:26 pm
It´s a base map. Which means the engine will start and run and thats it. Remainder is calibration.
Gunni
craigieeb
Post Sun Jul 29, 2012 7:40 pm
I'll have to get it sorted out before driving it tho,
theres no way I can drive it to the end of the road,
let alone 270odd miles down to you, the way it is now mate
Gunni
Post Sun Jul 29, 2012 9:03 pm
We will sort it out through some logging and things. Not to worry.
Gunni
craigieeb
Post Sun Jul 29, 2012 9:05 pm
Sweeeet cheers dude
craigieeb
Post Sun Jul 29, 2012 11:18 pm
Wow, I thought it was about time to start tallying up what its cost, and this is what I can think of at the moment....
Engine-£300
Turbo-£650
Vems-£640
Loom-£150
Loom Mod to fit to VEMS-£175
Wastegate-£250
Arp Bolts/Head Gasket-£300
Manifold/Exhaust-£1000
Dumpvalve-£40
Paddle Clutch-£300
Fuel Pump/Injectors-£355
Gearbox-£50
Diffx2-£440
Rear Diff cover-£30
Diff Oil-£40
Engine Oil-£50
Propshaft-£40
Rockercover Gasket-£30
Sump Gasket-£30
Spark Plugs-£55
Powder Coating-£60
Engine Mounts-£40
Gearbox Mounts-£20
Intercooler-£90
Intercooler Pipes-£65
Laser Cut Manifold Flanges-£50
Oil Pipes For Turbo-£50
Clamps For Exhaust-££65
Silicone Hoses-£60
Clamps/intercooler-£20
Boost Gauge-£15
Fittings/Nuts Bolts etc-£70-£80
Vacuum Hoses-£15
Turbo Jacket-£45
Oil Fittings for Turbo (feed/Drain)-£25
Water Pipes-£40
Wheels-£250
Control Arms-£120
Drop Links-£40
Brake Pipes-£50
10MM Fuel Pipes-£45
Tyres yoko Ad048's-(secret)
Brake Pads-£100
^^ nearly all of this is + postage costs and fuel costs,
But Minus labour costs.
There'll be loads i'v forgot about, this is just off the top of my head.
Oh yeah 1 More thing.......................
Help From The Zone- PRICELESS!!!! ; )
rix313
Post Mon Jul 30, 2012 9:54 pm
Just read through all this. Been a bit of a journey. Credit to you for cracking on with it :)
leeparkes
Post Mon Jul 30, 2012 11:18 pm
Just done a quick skim calculation and thats about 5.5k, its so easy for the cost to mount up with a turbo conversion aint it. 8O
How much does the missus think its cost? :)
craigieeb
Post Mon Jul 30, 2012 11:47 pm
rix313 wrote:Just read through all this. Been a bit of a journey. Credit to you for cracking on with it :)
Cheers Rich,
Yeah it's had its ups and downs, but doesnt every conversion,
I'm glad I stuck with it, cant wait to drive it properly :cool:
leeparkes wrote:Just done a quick skim calculation and thats about 5.5k, its so easy for the cost to mount up with a turbo conversion aint it. 8O
It's still racking up and up..Brakes, suspension,oil pump, sump etc
I dont want to know the real total of what I'v spent on this car, its scary :eek:
The missus is ok with it tho,
she got her cooker
:chuckle:
blackE30indy
Post Tue Jul 31, 2012 10:47 am
Looks good mate,bet you can't wait to drive it :twisted:
craigieeb
Post Wed Aug 08, 2012 8:32 pm
Time for a little update me thinks...
So, its been a bit crap really lol
the car would start have an erratic idle,
then die,
it would only idle at around 1200 rpm with the throttle open 7% ,
anything below that and it would just cut out,
Managed to get it up to temp a few times, but once it was switched off,
it just wouldnt start again.
I'v been speaking with gunni nearly every day for a while now,
and hes been a legend!!!
He's been tweeking the settings on the ecu and sending me the files,
i'v been putting them on and reporting back to him,
One setting he sent over, made the car work for a while............
I say while,
I managed a 7 minute test drive till it cut out at a roundabout, and i had to be rescued :(
so i had made a log file and sent it to Gunni,
he did more tweeking, and sent me more setting.
and also restricted me to 0.5 bar, because it was boosting too much,
that was my fault, as I had put the vacuum line into the wrong port on the wastegate, so it was running at 1.6 bar
He restricted it just so he could see what was what, till the fuling has been sorted out, then it'll be back on boost
So today, I managed a good test drive of it, its slow as hell with it being restricted to 0.5 bar :(
it seems to "just" come on boost, then cut off...straight away,
Still feels like its going to stall, when i come off the throttle
but to get it running properly I need to get it re-mapped
which will be happening soon :D I'll be taking the car down to see Gunni
for a live rolling road mapping session, to unleash the power
:D :D
samc
Post Wed Aug 08, 2012 9:23 pm
craigieeb wrote: I managed a 7 minute test drive till it cut out at a roundabout, and i had to be rescued :(
smokey audi to the rescue :mad:
craigieeb
Post Wed Aug 08, 2012 9:35 pm
I made sure the smokey golf was on breakdown duty today lol
samc
Post Wed Aug 08, 2012 9:36 pm
good old vag's :wink:
craigieeb
Post Wed Aug 08, 2012 9:39 pm
samc wrote:good old smokey vag's :wink:
:P
Gunni
Post Wed Aug 08, 2012 10:47 pm
A few more emails and it should all be ready for smooth sailing.
Gunni
craigieeb
Post Fri Aug 10, 2012 7:47 pm
It was sooooooo close to smooth sailing
but........................
Disaster has struck!!!!!!!!!!
I'v got a problem, a real problem with oil starvation,
I was out working on the car, trying to find a misfire, just letting it sit on idle
and i heard a "knocking" :eek:
so switched it off, stood about for a few seconds, and thought hmm has it gone..?
started it back up again and it was defiantly still there,
it seemed to be coming more from the top than the bottom end,
so today i'v just been out and ripped the rocker cover off, pulled a couple of the inlet cam caps off,
only to find they were scored to death!
so out came the inlet cam
and that is also scored to death!
Click for larger pics
the exhaust cam is fine, the lobes on both cams were dripping in oil, and there's defonatly oil getting to the turbo,
I'v checked the oil pathways on the cam carrier and there are no blockages ://
does anyone know why has this happened?
has this happened to anyone before?
and
obviously i'm going to have to replace..
the cam,
the cam caps
and the cam carrier,
so daft question coming....
I'v got a 2.8 engine sat here,
are the cams and carriers interchangeable?
the 2.5 is a non vanos and the 2.8 is a single vanos, any difference besides the vanos?
But really need to find the cause of this before i just go slapping another cam in, at the moment, i dont have a clue :(
Post Fri Aug 10, 2012 7:53 pm
Are the carriers the right way round? check the oil ways line up with the head, cam and carriers are different yes, I might have one in my shed if you need?
rich318i
Post Fri Aug 10, 2012 8:09 pm
going by the pic they are the right way round
craigieeb
Post Fri Aug 10, 2012 8:10 pm
DanThe wrote:Are the carriers the right way round? check the oil ways line up with the head, cam and carriers are different yes, I might have one in my shed if you need?
Yep, there the right way round
just had to double check
rich318i
Post Fri Aug 10, 2012 8:18 pm
did you do any work at all the the cams area for the turbo converion?
craigieeb
Post Fri Aug 10, 2012 8:20 pm
The whole engine had a rebuild,
and everything was cleaned and double cleaned before anything was fitted
rich318i
Post Fri Aug 10, 2012 8:27 pm
gutting mate feel your pain.
rich318i
Post Fri Aug 10, 2012 8:37 pm
sorry mate but did you prime the carriers up with oil as you rebuilt it? cos it could of sealed them off from no oil
Post Fri Aug 10, 2012 8:44 pm
rich318i wrote:going by the pic they are the right way round
How does the pic tell you this? there are no markings or oil drillings on display... :?
rich318i
Post Fri Aug 10, 2012 8:48 pm
by the cam guide at the front
