Best engine to turbo? completed & the results are in :)
craigieeb
Post Sat Jul 21, 2012 6:16 pm
I dont know mate,
I'll have a look on their forum,
But I dont want to be messing with the settings on the vems,
It's definitely not my area,
Im just a driver :), so I'll stay well clear,
That's why I asked gunni to load the base map for me before he sent it back,
Because I wouldn't have a clue where to start :?
craigieeb
Post Sun Jul 22, 2012 4:23 pm
Hmmmm just been outside to put the lights and grills back onto the car,
and while i was putting the connectors into the back of the lights,
i brushed past the metal part of the MAF with my arm,
and the fooker is hot!!
iv got a feeling it shouldnt be like that,
the car hasnt been touched since yesterday,
and the ignition is not on as the key is in the sittingroom........
why is the MAF hot anyone??
it was tested on another M50 before i got it and it worked perfectly
Andeep
Post Sun Jul 22, 2012 4:30 pm
MAF? Vems runs off MAP doesn't it?
craigieeb
Post Sun Jul 22, 2012 4:37 pm
I dont think so,
there are no provisions/connectors for a MAP sensor to be plugged in,
only the MAF
Andeep
Post Sun Jul 22, 2012 4:57 pm
I'm 99% sure vems runs off a map sensor.
Andeep
Post Sun Jul 22, 2012 5:10 pm
Yup just checked and runs off map and air temp sensor.
craigieeb
Post Sun Jul 22, 2012 5:15 pm
Hmm,
i thought with there being no connection for a MAP
and only the connector for the MAF, thats how it connected up,
so does this mean i have to change the wiring/connector that goes to the MAF
for a MAP connector..?
and then also buy a MAP
Andeep
Post Sun Jul 22, 2012 5:18 pm
Did you get it through the group buy? Check the thread, it says that the ecu comes with map sensor
craigieeb
Post Sun Jul 22, 2012 5:22 pm
Yeah I was in on the group buy
But
Mine didn't come with one :?
sag
Post Sun Jul 22, 2012 5:33 pm
craigieeb wrote:Yeah I was in on the group buy
But
I mitht be wrong but I think the MAP sensor is built into the ECU
Ill double check mine
sag
Post Sun Jul 22, 2012 5:39 pm
But
Yeah I think it's built into the ecu between the two plugs there is a vacuum connection. Which if I'm right it's for the MAP
craigieeb
Post Sun Jul 22, 2012 5:44 pm
Cheers sag,
I thought the vacuum pipe on the ECU was for boost control..?
sag
Post Sun Jul 22, 2012 6:36 pm
I'm confused now. It's best to ask Gunni.
I assumed the vacuum port on the ECU was for MAP as I bought a boost control solenoid from Gunni for extra money.
Petka
Post Sun Jul 22, 2012 6:41 pm
vacum port on aftermarket ECU is normaly for map sensor.
Boost controller is normaly seperate box from ecu
ross_jsy
Post Sun Jul 22, 2012 7:00 pm
This is from a PM I received from Gunni a while ago when I enquired about VEMS:
"Maf gets removed.
The PnP runs a Speed Density setup (map sensor based)"
So not sure why you have a MAF.
craigieeb
Post Sun Jul 22, 2012 7:15 pm
EH!?!?
My head's battered :? :mad:
I just need someone to tell me what to buy or what to do to get this running :)
Post Sun Jul 22, 2012 7:20 pm
Get your wallet out :)
craigieeb
Post Sun Jul 22, 2012 7:27 pm
Its out and open :) but I dont know what to do with it lol
Andeep
Post Sun Jul 22, 2012 7:46 pm
Disconnect the MAF and take it off wherever it's connected, vems runs off map. Then connect a vacuum/boost feed to the vems unit.
craigieeb
Post Sun Jul 22, 2012 7:53 pm
The MAF is off now.
If I take a feed from the turbo to intercooler pipe, direct to the ECU vacuum nipple,
would that do it?
Andeep
Post Sun Jul 22, 2012 8:21 pm
Think it's best to take a feed off the intake manifold. For now just take a boost reading from anywhere and see if it fires.
craigieeb
Post Sun Jul 22, 2012 8:35 pm
Ok will do,
i'm thinking of putting a "T" piece in the hose running between the inlet and the pressure regulator, then onto the ECU?
These MAP sensors....
i'v just hunted about for the box that the vems came in,
I found it :) and in the bottom of the box was this sensor..
Is this supposed to go in place of the standard air temp sensor then?
sag
Post Sun Jul 22, 2012 8:41 pm
craigieeb wrote:Ok will do,
then?
That's looks like a air temp sensor
craigieeb
Post Sun Jul 22, 2012 8:45 pm
sag wrote:That's looks like a air temp sensor
It does doesnt it,
Oh well
Whatever it is, it doesnt fit anyway
:lol:
Andeep
Post Sun Jul 22, 2012 9:14 pm
Yep that's a temp sensor. Best to ask gunni if this replaces the factory BMW air temp sensor
Gunni
Post Tue Jul 24, 2012 9:24 pm
That air temp sensor needs to be fitted to the intercooler pipes.
Gunni
@ 2012 VEMS group buy !!
craigieeb
Post Tue Jul 24, 2012 9:29 pm
I can sort that tomorrow, i'll just drill and tap the inlet intercooler pipe :)
And does that just run off the standard air temp sensor connector?
i.e unplug the air temp sensor and plug it straight into this sensor?
Gunni
Post Tue Jul 24, 2012 10:25 pm
Yes , just plug this into the original air temp sensor plug.
Gunni
craigieeb
Post Tue Jul 24, 2012 10:29 pm
:cool: :cool:
Andeep
Post Thu Jul 26, 2012 11:52 am
Any luck mate?
craigieeb
Post Thu Jul 26, 2012 5:47 pm
Yes :)
First of all, I have to say a big thank you to everyone that has helped me along this project,
from deciding which engine to use up to the end of the conversion :cool:
And a BIG thank you to Gunni, without him,
I wouldnt of had a turbo, a VEMS ECU :P or been at this stage right now
[youtube][/youtube]
Its still not quite complete yet, the idle sits a bit high and its overfueling at the moment, nothing a bit of tweeking with the ECU wont fix
and theres just a few little jobs that need doing, before I take it on a test drive, then on for an MOT,
but I have to say I am a HAPPY MAN :D :D :D
Its been emotional :thumb:
Andeep
Post Thu Jul 26, 2012 10:27 pm
Very nice mate !
sag
Post Thu Jul 26, 2012 11:07 pm
Well done mate!!
I'm hoping to finish my conversion soon, but there has been a few delays already. But hopefully in next couple of months.
Post Thu Jul 26, 2012 11:33 pm
Damn that vid is such an anti climax! Rev the coont man! :D
Andeep
Post Thu Jul 26, 2012 11:34 pm
Haha I was gonna say I wanted to hear a rev!
