I have just done an oil
Change on the z3 1.9 and when checking the level on the dipstick(never ran the engine) it was black as fook on the dipstick.
Is this a sign of a serious engine problem developing?
Tia
Oil still black after oil change z3
macas
maxfield
Did you do the oil filter before or after you changed the oil?
The oil filter housing holds oil and when you take the filter out black oil will drain to the sump.
macas
I did the oil filter before i put the new oil in,i was just shocked that the brand new oil by the time it got into the sump was black again,i spoke to a chap at the garage and he did say change it agsin after 2000 miles?
Im also getting a very lumpy tickover,the revs on tickover are smooth but you can feel the lumpiness of the engine,iv changed the plugs thinking it was that but to no avail?
I have no air leaks etc,so im stumped
macas
Aahh,thanks for that,i will look into that,how would i check wether my current one is faulty?also would this causemy fuel consumtion to be quite high?(which i forgot to mention)
maxfield
Ideally it would need to be put on a scanner for a definite answer as to the problem.
But yes the O2 sensor could cause the above faults.
macas
Iv just thought,i had the front section of the exhaust replaced about 3 months ago,would that have come with a new oxygen sensor or instslled the old one?
ross_jsy
It wouldn't come with one no, and removing and refitting the current one means it could get damaged.
Get the engine nice and warm before draining the oil?
If its black after just being put in id be changing it after a few hundred miles, not thousand
